Grand National engine/tranny ???
Old Sep 27, 2001 | 12:58 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
A friend of mine has a totaled GN and he's considering selling the engine, tranny, and rearend out of it. I know the TTA had the same engine so I'm wondering how much of this will be compatible with a thirdgen, and how much fabrication it'll require if I decide to do this. Also, what's a good price for the setup? I believe the GN was running low 12s before it was wrecked.
91 Z28
Come see The Vicious...
Old Sep 27, 2001 | 02:11 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Im not sure but I believe it can be done. I the difference between the TTA and GN motor is the accessory setupa nd location much like the difference between an L98 vette/F-Body.
Search the archives, and I'm sure you'll find some info on it.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, MSD 6A, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's, Accell 24# injectors
1989 Chevrolet Celebrity Eurosport <--DEAD AS OF 9/20/01
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
Old Sep 27, 2001 | 02:32 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
you will need custom headers and exhaust made for it, GN manifolds won't fit and TTA ones are nonexistant. you will also need different engine mounts, and maybe a tranny mount but i'm not sure. i know the GNs had a vaccum pump type thing to run the vaccum booster for the brakes, you will need one of those too. it won't be an easy swap by any means but it would be cool.
86 IROC
43,000 miles
305/700R4/3.23 gears
maroon, gold stickers, black interior, T-Tops.
current mods.
shift kit
headers
cat back exhaust
mods planned for this winter
cam
3.73 gears
subframe connecters
Old Sep 27, 2001 | 03:09 PM
leirch's Avatar
As long as you don't need AC you should be ok.
Old Sep 27, 2001 | 06:18 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
The GN engine and TTA engine is NOT the same. Different heads pistons and the crank is crossdrilled in the TTA motor. You can keep the GN heads but you'll have to ditch the AC.
Go to one of these site for more info
www.turbobuick.com www.turbobuicks.com or www.gnttype.org
They'll help ya out..i'm planning on doing this swap as well...the potential of these motors are unbelievable
Also a guy by the name of TTA850 knows a thing or two...personal friend of mine...he swapped one into his 89 GTA go for 9's he also has 2 TTA's(that bastard )
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Sep 27, 2001 | 06:19 PM
fly89gta's Avatar
Car: 2018 Camaro SS
also with the 200-4r tranny u will need a new crossmember and a different driveshaft(i think) and a different torque arm as well
[This message has been edited by fly89gta (edited September 27, 2001).]
Old Sep 27, 2001 | 11:50 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i do have some fairly decent pictures of the turbo trans am set up. you may be able to get some of the stuff needed to swap it from gm yet. as far as price, anything under 1200 would be worth it for the engine and trans. that rear end would be valuable if he sold it too. not many 8.5 10 bolts for g bodies out there.
Linson
Oct 24, 2025 02:00 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
meeklay812
Oct 1, 2015 03:46 PM
scottmoyer
Sep 7, 2015 07:06 PM
tgp1990
Sep 4, 2015 06:24 AM
