Simple question...
Old Jul 24, 2005 | 03:43 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Simple question...
I get different answers from everyone I talk to.
Is the line in between the 100 and 220 160 degrees or 190?
Old Jul 24, 2005 | 06:26 AM
IroczInOz's Avatar
Good question I have always thought the middle line was 160?
So I'd be interested too what the verdict was.
Old Jul 24, 2005 | 07:43 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I'd say it is 160. On my car with a 200/180 fan switch, the fan cuts off before the needle gets down to the line.
I also have a 180 stat and the needle is usually just above the line when driving around town.
Old Jul 24, 2005 | 07:45 AM
cheyenne383's Avatar
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
160, but keep in mind it's not the most accurate guage in the world.
Old Jul 24, 2005 | 10:33 AM
Rockin-Iroc's Avatar
Car: 1986 IROC-Z
Engine: 355 ci TPI, 10:1 cr, Isky cam, ported heads, dual exhaust
Transmission: 700R4, ratchetting shifter, 3.23 rear
Yeah that's for sure. Mine's off by exactly 22 degrees.
If you want accuracy, consider an Autometer 3-pack, and put them either on the pillar or underneath the center vents.
I'm considering that myself. My oil pressure gauge quit working entirely, and the voltmeter varies as well. Stock gauges are crap. They're barely more than idiot lights.
Old Jul 29, 2005 | 07:53 PM
IroczInOz's Avatar
Rockin Iroc, maybe check your contacts on the back of the gauge cluster. They do thend to play up with the cluster is not seated properly.
I don't really have much complaints with the stock gauges, but the water temp gauge is a bit off on mine too.
Old Jul 30, 2005 | 06:57 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Simple question...
The first unmaked dash is 160 Deg, and increases by 20 Deg after the 220 mark.
100
160
220
240
250 start of the red zone
260 top of the red
Now whats so hard about that? As quoted not the most accurate gage, but that what you have to use.
Old Jul 30, 2005 | 02:08 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Re: Re: Simple question...
I always said it was 160, but people kept saying 190.
Old Jul 30, 2005 | 02:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Re: Re: Simple question...
190 huh?
So the needle would take longer to reach the first marker, than it would to go from the first to the middle (given a constant rate of heating up)? That would be interesting!
Old Jul 30, 2005 | 02:47 PM
DJP87Z28's Avatar
Now I have a 180 deg thermostat and my gage will peg a little less then mid way between 160 & 220 with the A/C off. So I can say my gage is pretty close. Now with the A/C on it tends to climb toward 240 degs mark.
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
