Motor help please
Old Jul 26, 2005 | 01:44 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Motor help please
I made a few posts asking for help ID'ing my motor.
Well I finally just took of the heads and measured the bores. They are 3.776 so that makes it a .040 305cu in right?
So now that I know it is a 305 and not a 267 like the casting numbers sites said it was I can get to work on the motor.
I want to put in new heads. So many folks have different opinions I don't know what to use.
The parts will not be swapped to a 350 down the road, it is a daily driver and won't be raced.
I don't want to port the heads unless I will realy see gains because I don't want to mess them up.
I have a performer carb and manifold and headers and good exhaust.
I just need a cam and heads.
What should I go with?
416's 187's 601's etc?
what do you all think?
Old Jul 26, 2005 | 02:13 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
I'd go with the world products S/R Torquer heads that are made for a 305. They flow more air than stock and will be useful for increasing your torque and hp. The hp jump varies, but you should get at least 30-40 extra ponies with a stock type cam.
Old Jul 26, 2005 | 02:19 PM
Car: 1989 Camaro
Oops! I almost forgot the cam. If it's a daily driver that you just want to have a little more pep, Go with a towing or rv cam from comp cams. If you want it to be a bit more powerful, I'd say go as high as 212 degrees of intake duration maximum. The exhaust should stay around a maximum of 218 degrees of duration. Stay in that area and you won't be disappointed during your daily trips to the store.
Old Jul 27, 2005 | 12:38 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Thanks for the info
I do like the S/R heads but unless I find a used set they are out of my price range. I was thinking of getting a set of rebuilt chevy heads I see them on the web and at auction sites for about 200 to 300 bucks. What chevy heads do you all recomend?
I have about a grand to spend. I need heads, distributor, spark box and if I can push it maybee a torque converter or different headers if my old ones wont fit the heads. I will be buying used or rebuilt for most of the parts
I never thought of the RV cam because its going in a car, but now that I think about it the power I will be using is in the low to mid range...just like a truck!
Old Jul 29, 2005 | 11:52 AM
2BoltMain's Avatar
Originally posted by TBITrucker
Thanks for the info
If you don't want to spend that much, find a set of 081 or 416 casting heads and rebuild them. As for a distributor, a stock GM HEI would work fine for a 305, if that's what you have, keep it, if it works, why spend money if you don't have to?
RV cam would be fine.
The money you save on a distributor, maybe get yourself a nice free flowing exhaust to match the headers.
An open element air filter as well.
Oh and if you have a carbed motor with a quadrajet(quadra-bog) replace that too.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
