Building vs. Buying an LS1
Old Sep 30, 2001 | 09:53 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
I was just curious since its fairly easy to find LS1 parts on Ebay...how hard is it to build an LS1?
Are they too much more complicated than a normal small block Chevy?
Old Sep 30, 2001 | 10:24 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Just more expensive.
Cams are easier to swap. (You dont have to remove the intake)
Headers, cams, heads, pistons, etc. are all available.
Go to www.ls1.com and ask around, a lot of people there have modded LS1s and they can fill you out on the $$ figures.
Keep in mind, just the engine in stock form with trans and a computer, I've seen go for 4 or 5 K.
Then you get into custom motor mounts, blah blah blah.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited September 30, 2001).]
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
