Compression Question
Old Jul 28, 2005 | 05:42 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
I was supposed to be getting a set of AFR 210s with 66c chambers, planning to run wiseco pistons (-5.4cc) and a .040 head gasket, yielding 10.8:1 compression. the shop i ordered the heads from fell through, got my money back, and now i found a deal on a set of 210s with 76cc chambers. i figured i would have to change the pistons to the 8cc domes, and run a .060 head gasket to yield a 10.7:1 compression. is there any harm in doing that, or should i just get them milled?
Old Jul 29, 2005 | 02:16 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Is this a 400 or 383? It is generally better to run the smallest combustion chamber as possible. Some of the premier engine builders are using 30-33cc chambers on 400+ cid's so...
Old Jul 29, 2005 | 03:06 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
383. looks like milling would probably be the way to go then
Old Jul 29, 2005 | 12:20 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I would never run domes.
Old Jul 30, 2005 | 03:16 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Just bolt a blower to it, with the 76cc heads and stop worrying.
Old Jul 30, 2005 | 03:25 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Quench will suffer with a .060" gasket.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
