carb
Old Jul 28, 2005 | 08:37 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
carb
ok i am converting from tpi to carb since the 305 spun a bearing got a 75 350 from a corvette and it needs a distibutor
intake and a carb. just wanted to know is there a special distributor that i need and for the intake im thinking a torqer 2
and a holley 650 carb. thanks
Old Jul 29, 2005 | 12:28 AM
Car: 1987 iroc z
just need to know what kind of distributor to get and how to hook it up
Old Jul 29, 2005 | 12:52 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
All you need is an older style HEI distributor
Old Jul 29, 2005 | 03:25 AM
Car: 1987 iroc z
like this one right but how do i wire it. http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem
Old Jul 29, 2005 | 06:06 AM
e-man's Avatar
Car: 89 formula
Engine: 383
Just use one of the wires from the stock coil (I think its the thicker pink one)that turn on with the ignition for your 12v and the white wire from the coil is your tach. That needs to go to the HEI distributor also thats it.FYI summit sells the power/tach wire pig tail connectors that fit the older HEI so you splice and plug in.
Old Jul 29, 2005 | 07:15 AM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Don't get the torker. It is a terrible intake. Go with a performer rpm or something.
Old Jul 29, 2005 | 09:47 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Yes that distributor that you listed will work
Old Aug 2, 2005 | 02:00 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
yea i hear that the torqer sucks
Old Aug 2, 2005 | 08:14 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
call the edelbrock tech line.even they will tell you the torker 2 is a pile of junk.if you plan on changing cams,the rpm is a nice manifold.if you are in emissions country,the performer is street legal everywhere.
a holley 650 is a great carb for a 350!rule of thumb(not etched in stone),vacuum secondary for auto trans,double pumper for standard trans(and if someone else pays for your gas)!actually you can get good(not great)mileage from a d/p if you keep your foot out of it.it's just not easy for me to do!
i got a remanufactured hei distributor from advance auto parts for $80,slapped an msd in cap coil and ignition module in it when $ permitted, and am VERY pleased with the stock appearing hei!
i must caution however,i have had trouble with remanufactured distributors from other parts stores.i went thru 4 just to get a good one for a chevy II many years ago!
E-man has the wiring correct
good luck!
Eric B
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
