Engine Guys========>>>>Woodruff key?????
Old Oct 2, 2001 | 04:59 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Where does the woodruff key go on an '89 5.7L? and how does it go there?
92Z28
89GTA
Old Oct 2, 2001 | 05:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Could be the one on the crank.
Old Oct 2, 2001 | 05:40 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Im thinking In the crank too. It lines up you harmonic balancer.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Oct 2, 2001 | 05:52 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I was under the impression that the keyway on the crank snout lined up the balancer. I could be wrong. Does the woodruff key go under the crank gear?
92Z28
89GTA
Old Oct 2, 2001 | 05:54 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Just to clarify, I am talking about the little piece of metal that looks like half of a nickel.
92Z28
89GTA
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. There is a keyway in both the balancer and the gear, and one in the crank. The key holds all those parts in the correct relation to each other.
ICON Motorsports
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
