car died while driving
Old Jul 30, 2005 | 10:13 AM
camaronick91's Avatar
Car: 91 z28
Engine: 350 stealthram
my car died while cruising at 40 mph. i saw the tach just drop off to 0. pulled over wont start. popped the hood dint see anything unuasual. 3 min later started up and drove home fine. could this be my 2 year old msd coil or my flame thrower ignition module,or something else.
Old Jul 30, 2005 | 12:34 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
if it just suddenly cut off without you noticing any spuddering etc then I'd guess that you have some electrical problems with your ignition system. Car not throwing any codes? doublecheck your wiring to your ignition box, and you might even consider having your ignition control module (in the dist. under the cap) checked out. When my ICM died, I was stuck. No spark. Had to replace the ICM. Let us know if you find anything out.
Old Jul 31, 2005 | 08:26 AM
Car: 91 z28
a little more info. its was running hot for an 1 1/2 hours. in stop a go traffic. what is heating up a shutting down . could be coil or icm. could it be pu coil? what shuts off when hot? then has the ability to cool off in 3 min to restart and drive.
and at the light before it died it hesitated for a sec , when it was diein the rpms were bouncing all over at low rpms. is this the coil?
Old Jul 31, 2005 | 12:35 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
This happened to me and it was the ignition module...once it cooled off the car would start...the module eventually died all together on a highway in nj during rush hour on a road with no shoulder....fun fun
maybe this helps
Ghettobird52
Jul 5, 2024 11:18 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
