check this out
Old Jul 30, 2005 | 11:20 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
check this out
ok this monday im deleting my A/C and i need to figure out what pulley is directly UNDER by A/C pulley? and if anyone knows once i get rid of that pulley what size belt do i need for the "unkown pulley" to the (water pump???) no clue wat that pulley is either....heres a pic of wat im talking about
Old Jul 30, 2005 | 11:42 PM
87350IROC's Avatar
Car: 87' IROC
the power steering pump is under the a/c... not sure what size belt you would need though, good luck
Old Jul 31, 2005 | 12:30 AM
Sidewayz28's Avatar
Car: 2001 Camaro SS
ohhhh ok makes sense thanks
Old Jul 31, 2005 | 01:12 AM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
y delete the a/c? only robs power when its on...
Old Jul 31, 2005 | 01:17 AM
Sidewayz28's Avatar
Car: 2001 Camaro SS
u know when its off its still "running"?everytime the pulley goes around the a/c its still running the ac....
1) to lose weight
2)seattle isnt sunny more than 20 days a year
3)t-tops
4)my windows roll down
Old Jul 31, 2005 | 01:29 AM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
I deleted my smog pump and used the belt from that.
Old Jul 31, 2005 | 02:22 AM
Sidewayz28's Avatar
Car: 2001 Camaro SS
ur ac gone too?
Old Jul 31, 2005 | 03:00 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
You should be able to just get rid of the AC belt altogether...the PS pump underneath is driven by two belts (the AC being one of them).
Old Jul 31, 2005 | 03:33 AM
Sidewayz28's Avatar
Car: 2001 Camaro SS
oh nice ill check on that if it is then definitly not guna even worry about it thanks for the heads up
Old Jul 31, 2005 | 06:58 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Just go to the autoparts store and tell them you don't have a/c and they'll sell you the right belt. The a/c is the only thing you're deleting right?
Old Jul 31, 2005 | 02:45 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
yes. but confuzed said above that the power steering is run by 2 belts...? correct?
Old Jul 31, 2005 | 02:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The A/C compressor pulley has a clutch that disengages so that the compressor isn't driven when the A/C is off.
Old Jul 31, 2005 | 03:14 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
that was just something i heard.....not my "theory" ............. but that doesnt change my idea of deleting my ac
Old Jul 31, 2005 | 03:25 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
im in florida....so im gettin ac for mine...98 today..who hoo ballsweat!
Old Jul 31, 2005 | 03:27 PM
Vader's Avatar
Perform a search for "delete pulley".
Old Jul 31, 2005 | 07:57 PM
Sidewayz28's Avatar
Car: 2001 Camaro SS
uh my brother told me that i cant take my a/c out because theres some substance that needs to be handled by a certafied mechanic?
Old Jul 31, 2005 | 11:00 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
that would be the refrigerant. ask around, there may be a shop up there that will recycle it & not charge you if it has pure R-12 in it.
Old Aug 1, 2005 | 03:58 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Yeah, especially with the price of R-12 being so high
Old Aug 1, 2005 | 04:27 AM
Sidewayz28's Avatar
Car: 2001 Camaro SS
well where do i get this refridgerent out w/out screwing sumnthin up?
Old Aug 1, 2005 | 10:43 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Don't throw it away
Send me your hoses !
I need some better ones, mine are all bent up
PM me.
Old Aug 4, 2005 | 03:00 AM
BRobinson's Avatar
Car: 82 Camaro
Axle/Gears: 3.08
Just call around to different shops. Cut your search times AND be environmentally friendly and look for the better shops. "Bubba's House of Car Repair and BBQ" isn't likely to be licensed to handle R-12.
Old Aug 4, 2005 | 03:03 AM
Sidewayz28's Avatar
Car: 2001 Camaro SS
already checked with a shop...21$ ..but im keeping the AC
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Numbah-1
Sep 12, 2015 08:57 PM
