Front End Alignment Q
I just had the front end aligned at Sears, since I had a new idler arm put in. I watched the guy do the alignment, and saw the computer readings change as he was adjusting things. All looked OK. But now the car pulls to the right on the highway, even more than it used to. When I called back and mentioned it, I got the tech, and he said he was surprised that it pulled either way, but that he would adjust it to compensate.
I asked if it could be the tires, and he said they might be "contributing" to the pull. Both front tires are worn in the inside edge, since the camber , or caster, whichever, was way out, but the left is worn a bit more than the right.
Maybe I should just switch the 2 front tires. Or move the rear tires, which have even wear, to the front ??
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder
than normal.
than normal. sounds like you just need a tire rotation and balancing..you've hit that one right on. If that doesn't fix it, then they perobably did a crappy job on the alignment.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
Car: Take
Engine: Your
Transmission: Pick
Passenger cars need at least .5° of Caster more on the right side then the left. This corrects most pull concerns to the right.
Another source of "pull" is whats called a "radial pull". Its in the tire, but don't condem a tire for it. Just swap sides on the front tires and see if it goes away.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Car: 4
Engine: 6
Transmission: 5
Right... the cause of a pull is usually the tires. Swap them from one side to the other and see if it changes it. Rear tires can cause it too, so try them if the fronts don't have an effect. After all, it's free...
Like GMTech said, there should be about ½° of caster split, and if the camber is different on the 2 sides, it should be more negative on the right as well. (These cars like about 1°-1½° of negative camber) Both of those things will tend to make the car want to turn, or actually drift, slightly left. Nearly all roads tilt to the right to drain rainwater, this alignment tweak helps compensate for that.
ICON Motorsports
ICON Motorsports
I remembered the tech dropped the tire pressure to 30 pounds all around before he did the alignment. Just for the heck of it I put 35 pounds in the 2 front tires, which is what I had before, and now it pulls much less to the right.
Must have been "radial pull" activated at the lower tire pressure. It is actually better now than before the alignment, as far as pulling right, so I may just leave it alone. Thanks for the replies and info .
Must have been "radial pull" activated at the lower tire pressure. It is actually better now than before the alignment, as far as pulling right, so I may just leave it alone. Thanks for the replies and info . Trending Topics
Terrell351
Jun 13, 2021 01:13 PM
