It's been slightly difficult to start my LO3 lately and it occasionally stalls at lights. I noticed that the TB isn't spraying when I turn the key to "run". Aren't the injectors supposed to spray prior to startup? I rebuilt the injectors about 8 mos ago so they should be fine. When the car eventually starts the spray pattern is appropriately conical. I also replaced the fuel filter within the past 8 mos. The only thing I can think of is may be the battery isn't putting out enough power but it cranks the engine just fine so that can't be it. Oh, I also replaced the fuel pump relay as well - same problem. What I don't get is eventually the injectors must fire or it wouldn't start. Any ideas as to what's going on?
89 RS V8,Borg-Warner 9-Bolt rear,Open element,Flowmaster.
No, the injectors will only fire if the car is turning over. The injectors are triggered by the turning of the distributor. Sorry, I can't really help you with your problem.
88 firebird formula - Old time with TBI - 13.9 @103mph, 2.6 60ft
350 Vortec, Accel Pro-Ram MPFI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
3 inch Flowmaster catback
I love pissing those LS1's off
My Formula
Edelbrock headers
T56 - SIX-speed
open 3.73's
My Formula
