What's with the 160 thermos?
Old Oct 5, 2001 | 02:18 PM
92Camaro305TBI's Avatar
I've searched the board and either I didn't see it or it wasn't there.
When changing the thermostat from stock to whatever it is 160, 170, 180, 195, to make your engine run cooler... im guessing.. Do you have to change or modify your chip? and if you do, Why is this so?
what does changing the thermostat really do..
I didn't see this in the tech article and would be really nice if someone put it in there,,,,
thanks
Old Oct 5, 2001 | 03:09 PM
Dan87IROC-Z's Avatar
No, you don't have to modify your chip when doing a thermostat change. Acctually, most aftermarket chips require a lower temperature stat because it increases your timing and can lead to detonation if the engine gets too warm. I live in CO and I use a 180 stat in my car and it runs perfect. I would only use a 160 if you live in AZ or FL or some hotter than hell climate.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 5, 2001 | 04:35 PM
wel lIm in florida.. so do you recomend me getting a 160 stat and chip...
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=6100
Old Oct 5, 2001 | 05:22 PM
un4givin89's Avatar
smacks head. There is no need for a chip. Just get a 160 and put it in. Its super simple.
Old Oct 5, 2001 | 05:44 PM
Hey is this a good deal then..? and is it what I need...thanks
http://www.slponline.com/view_produc...TNUMBER=100222 160º All SBC Chevy Engines
SLP’s thermostats reduce coolant temperature which helps produce more horsepower. They’re easily installed, require no modifications and are one of the most cost effective ways to improve your vehicles’ performance.
P/N:100222 Thermostat, 160º All SBC Chevy Engines
[This message has been edited by 92Camaro305TBI (edited October 05, 2001).]
Old Oct 5, 2001 | 06:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The benefit of the 160* stat is that it reduces underhood temperatures causing cooler air to enter the intake. This will result in minor HP gains.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 5, 2001 | 07:41 PM
Z28DJP1987's Avatar
Go NAPA auto parts and buy a 160 deg supertat
for $6.99
Old Oct 5, 2001 | 08:42 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Keep in mind, and some people will get pissed, but lowering your coolant temp will cause reduced cylinder temperatures, which results in a less efficient combustion of air/fuel.
You actually lose power by running an engine too cold. fuel economy can suffer as well (especially on computer controlled cars where the stock chip relys on a stock stat setting)
However the reduced underhood temp will allow denser air in, so it pretty much equals out.
It's the farmer way to produce a cooler intake charge.
Generally, the hotter the engine (or rather, the combustion) the more power it makes. The challenge is getting as much air in as possible (cold air/force induction)
if you want to get proffesional about reducing underhood temp. purchase header wrap/insulation, setup a CAI or ram air, insert air vents to remove as much heat as possible from the engine bay.
then again, changing your stat is much easier.
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Nervous2
Oct 8, 2015 10:53 PM
jaridjohn
Oct 5, 2015 07:01 AM
