car running rich with no error codes..
Old Aug 4, 2005 | 05:10 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have a ccc q-jet on my 305 with the ecm and when your behind the car your eyes water, i installed a heated o2 sensor and that did not fix the problem, i checked the coolant temp sensor also, everytime i drive this car i personally stink like it after i get out of it and come in the house, it's pissing me off, i dont think the lg4 computer has the field service mode, i'm out of ideas, oh yeah i checked the tps sensor and thats good also
Old Aug 5, 2005 | 10:57 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Check your E.G.R. valve and tune or adjust the carb. Also check your air filter.
Old Aug 6, 2005 | 08:18 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Not sure on the field service mode, though it had it but ??
Have you pulled the plugs to see if there is a problem in maybe just one hole?
Datalog? I have a feeling you aren't getting into closed loop.
Old Aug 7, 2005 | 06:37 AM
Vader's Avatar
This might help:
https://www.thirdgen.org/techbb2/sho...hreadid=312358
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
Kaweh
Aug 9, 2015 02:54 PM
