Not another VATS thread....
Old Aug 4, 2005 | 11:53 PM
HillbillyJeeper's Avatar
Car: 1975 IHC Scout II
Engine: 1967 Buick 340 with TBI
I have a VATS qusetion. MY 92 firebird has VATS. The preivous owner made it run by jumping the starter relay. Thats it. I went ahead and put the relay back in, and grounded the ground wire. But why does it start? The computer should cut fuel to the injectors untill it gets a signal from the VATS module. I have done anything, nor he, to that part of the system. I went so far as to cut the wire that goes from the VATS module to the computer, and it still starts. The only thing i can figure is someone changed the computer along the line. And if so, is there any way to tell? Its obvious is been out and unplugged.
Old Aug 5, 2005 | 08:51 AM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
jumping the relay will let the engine crank but like you said not start. Changing the computer (unless you're not swapping the mem-cal) won't do anything, but swapping in a new mem-cal will. Either it's got a new mem-cal/chip/prom (check broadcast code), or there's an appropriately sized resistor hooked to the Vats module and the relay wasn't working correctly to begine with.
Old Aug 5, 2005 | 09:10 AM
The wires to the VATS module have just been cut. So unless its really hidden somewhere, therse no resistor that i can see. (oh, and the relay works, becuase with the relay hooked up right, no crank. So all i can see is someone changed something in the computer, but it dosent look that way, unless they changed the hole computer. Where is the broadcast code?
Old Aug 5, 2005 | 11:05 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
There are 2 firmware switches in the EPROM code:
1) VATS Select x=enable
2) VATS Diagnostics x=enable
VATS select enabled:
Will fire the enjectors only if it receives the correct frequency signal from the VATS module.
VATS select disabled:
Injectors fire without signal from VATS module.
My '88 is VATS select disabled because it has no starter relay.
Old Aug 5, 2005 | 01:09 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
Broadcast code is right on the mem-cal under the door on your ECM, usally 4 letters (ie: ANYX). I think you can cross reference it with the list here on TGO. But if your wires are cut then it's gotta have a non-stock or modified chip (mem-cal) in it (not necessarily a bad thing )
*edit* - scratch that cross referencing here, they've only got the TPI listed. Either way something has to have changed with it.
Old Aug 5, 2005 | 08:10 PM
I can read "APFN" on the chip, but therse also 4 other letters/numbers that i cant read because a plastic thing is covering it. None of the wires where cut, but the connectors to the ECM had been removed at some point. I know most of you are thinking i should be gald, because it starts and all. BUt, not that its related, but i've been having a rough idle problem, so im checking all possible things. I have reason to believe some things have been changed, since the car has a tranny cooler and a 2500RPM stall converter, As well, the injector plugs have been replaced, but that may have just been maintance.
Old Aug 6, 2005 | 09:00 AM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
APFN should be all you need but I have no idea what is supposed to be in a '92 TBI. Almost sounds like somebody swapped a computer in from a similair-but-not-exact vehicle and never swapped mem-cals. Check with your local dealer and see if you can find out what is supposed to be in there.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
