Broken TPS Sensor
Old Oct 4, 2001 | 11:38 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Broken TPS Sensor
When I las rebuilt my carb, I accidentally broke the pin on the throttle position sensor. The sensor is still in the carb, and its plugged in, so no error code. But since the pin is broken, it will not push down when i press the gas and it will always read as if the engine is at idle. The engine runs fine, so what could this hurt? Is it worth tearing the carb apart and replacing?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Oct 4, 2001 | 12:02 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
What you are experiencing is a perfect example of how stupid early CCCS computers are. It's hard to say exactly what your computer is doing thinking the throttle is closed constantly, i guess the worst part is that at WOT it will stay in closed loop *attempting* to correct to 14.7:1, but since the primaries don't affect WOT at all in a qjet (practically anyway, verifed w/ several back to back runs adjusting MCS travel, no clear effects going rich or lean) i guess it won't hurt you much.
If you can verify it does get closed loop (monitor the O2 sensor output on a DVMand look for cross counts) and it's not giving you any driveability issues then screw it. If you're not getting closed loop and it is actually defaulting to PE mode then you are most likely fouling you combustion chambers up pretty bad, as well as getting a lot worse gas mileage than you could be.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.8 @ 93.1
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 4, 2001 | 07:07 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I get about 15mpg, I think thats pretty good for a carbed 400...
[img]www15.brinkster.com/fbody/pics/ward1.jpg[/img]
1983 Firebird
TH700R4 Auto
Small Block 400
Old Oct 6, 2001 | 09:22 AM
Ed Maher's Avatar
Car: 04 GTO
I'm just saying, it's in your best interest to make sure it is getting closed loop. 15 wouldn't be a bad city number, but unless you have really steep gears highway should be into the 20s. Also, the combustion chamber/piston tops get all carboned up if it doens't catch closed loop.
But WOT, like i said, i doubt it makes a difference.
92firebirdguy
Sep 1, 2016 07:53 AM
skeltor
Feb 2, 2016 10:37 AM
earlpote
Sep 12, 2015 11:55 AM
m00n420
Sep 11, 2015 02:39 PM
