smog pump removal
Old Aug 25, 2001 | 05:09 PM
cobrakiller1989's Avatar
smog pump removal
If i remove my smog pump and plug all of the holes that it leaves behind, will i have any trouble codes or any other problems? I am ready to take it all off, but i just want to be sure that i wont have any problems. thanks alot
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Aug 25, 2001 | 05:49 PM
I Cant Think of Anything's Avatar
I have taken off my smoge pump and i had no problems at all. The computer won't post a code because it won't know it's gone.
Hope that helps you out,
Luke
1989 Iroc-Z Blue T-Tops
Modes:
Headers, B&M tranny, K&N's
Old Aug 25, 2001 | 06:49 PM
firbird's Avatar
I Cant Think of Anything, Welcome to the board, i cant think of anything else so say but people here help a lot.
[This message has been edited by firbird (edited August 28, 2001).]
Old Aug 26, 2001 | 10:23 PM
Iroc n roll's Avatar
Ditto, welcome to Thirdgen.org. I have taken out my AIR pump as well. Just plug the AIR tubes on the headers and your set. It would probably be a good idea to drop the cat too since without the AIR it clogs easier (AIR system helps cat break up Hydrocarbons). Email me if you have any other questions about it, I will try and help you as much as I can. It's pretty easy though, just make sure you have both Metric and SAE sockets. You need to buy two 1/2" pipe caps to replace the check valves on the headers.
Old Aug 26, 2001 | 10:25 PM
thanks for the help guys. my cat is already gutted so that isnt a problem
*1989 RS
*355 CID
Old Aug 28, 2001 | 06:00 AM
RS91's Avatar
What is the purpose of removing the smog pump? Will it increase my HP?
Thanks..
Old Aug 28, 2001 | 10:22 AM
Removing the pump will do three things. First, it will reduce some weight in the front end of your already way too nose heavy F-body. Second, it will reduce parasitic loss on your engine because it doesn't have to spin the pump pulley any more. And third, it'll unclutter your engine bay. You probably won't feel a difference but you'll definitely gain a few horses, and they add up after a while. Every little bit helps . What you will notice though is much cleaner and more open engine bay which is well worth the time.
Old Aug 28, 2001 | 06:44 PM
RS91's Avatar
I have my cat removed already...If I'm done with the rest of the problem with my car I will try removing my smog pump also, just to clear my engine. I have learn so much from this forum and I enjoy learning new Ideas
thanks..
Old Aug 28, 2001 | 10:26 PM
No sweat... thats what we're all here for.
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, Dropped Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to askulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Sep 10, 2001 | 09:36 AM
RS91's Avatar
After Removing the Smog pump, can I still use the original belt?
Old Sep 11, 2001 | 12:45 PM
VortecZ's Avatar
Car: Camaros
The part number for the belt is Gates #K060935 if you are using power pullies. I'm not sure of the number without pullies. Maybe someone else can help.
Old Sep 11, 2001 | 01:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by Iroc n roll:
Removing the pump will do three things. First, it will reduce some weight in the front end of your already way too nose heavy F-body. Second, it will reduce parasitic loss on your engine because it doesn't have to spin the pump pulley any more. And third, it'll unclutter your engine bay. You probably won't feel a difference but you'll definitely gain a few horses, and they add up after a while. Every little bit helps . What you will notice though is much cleaner and more open engine bay which is well worth the time.</font>
#2 is next to nothing. If you do it, you won't notice any difference in 1/4 mile ET, for instance. I know, I kept track of ET's before and after - zero difference.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 CC system w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker 2055 headers, 3" Catco cat & 3" catback, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Sep 11, 2001 | 02:56 PM
leirch's Avatar
Who cares about a power increase. The point on the entire assembly being gone in your engine bay is WELL worth it. I did away with my AC also. Check out a shot of my engine bay(in the signature).
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Old Sep 11, 2001 | 04:39 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Just like to add my 2 cents as one more guy that's happy with his decision to remove his smog pump.. goin on 4 months without it and no problems. I'm keeping an eye out for signs of a clogged cat, but plan to replace it soon anyway
Old Sep 11, 2001 | 07:48 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Welcome to the group man! I tell you it is worth it to remove it just to be able to see the passenger side valve cover again!
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Old Sep 12, 2001 | 02:23 AM
MarkS's Avatar
Maybe this is a lame question, but can removing the smog pump decrease the life of the oxygen sensor?
Old Sep 12, 2001 | 02:04 PM
five7kid's Avatar
Not likely. The A.I.R. only goes to the manifolds when the engine is cold. After that, it all goes to the cat.
Old Sep 12, 2001 | 04:42 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I've heard that removing the air pump actually decreases power. Something about it helps evacuate the exhaust quicker?? Only heard that once before. Does it make sense?
Old Oct 4, 2001 | 12:44 PM
sunbound's Avatar
Car: 1987 IROC-Z
i have never had emisions on my car... previous owner took them off. but i do have 1 question... the two connections to the smog pump... dont this hook inot the computer? if they do, why wouldnt the computer know theyr not their?
later
jon
Old Oct 4, 2001 | 01:49 PM
92Camaro305TBI's Avatar
well i removed my pump...
No codes... so obviously it doesn't see it or doesn't care... or doesn't read it.... im still in the process... wating for some more answers
The coolant bypass has nothing to do with the smog pump RIGHT???
and i need a part number for the belt to use after removing the pully...
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=6100
Old Oct 4, 2001 | 02:04 PM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
AIR pump and plumbing gone, no codes, the ECM does not check to see if the solenoids are hooked up. Take off the belt, and go to local parts store and ask for the same thing but 1" shorter.
Installed a hi flo cat too, muffler shop assures me that the newer designs will not clog as they are built to work either with or without AIR.
Next, on to the coolant bypass.
Cheers
Richard
Old Oct 4, 2001 | 02:07 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
The computer is clueless to the fact that the pump and air divert solenoid are gone. I've hooked it up to a scanner and watched it; the computer is just commanding away, completely oblivious to the fact that there is nothing to recieve it's commands. Very cool.
91 Z28
Come see The Vicious...
Old Oct 4, 2001 | 10:43 PM
un4givin89's Avatar
BIg question here guys, first, how do you remove the smog pump and second, will the car remain street legal and still pass inspection?? I live in Virginia, own a 305 TBI.
Old Oct 4, 2001 | 11:04 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
This is my engine minus AC and AIR . It still passes e check.
89 FORMULA 350
99 Grand Prix GT
Old Oct 5, 2001 | 12:26 AM
un4givin89's Avatar
what the hell does this thing do?
Old Oct 5, 2001 | 12:05 PM
un4givin89's Avatar
we're not gonna hear much more on this are we
Old Oct 5, 2001 | 01:00 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
The fan belt on my smog pump broke off last week and i haven't have a problem yet, i felt alittle bit of horse power increase, now i just have to take the pump itself off now.
My $0.02
Chevy 2.8L 60° V6
Mods:
?K&N Filter Lid
?87 Formula Hood
?Bosch Platinum +4
?Hi-Flo CatCo CAT
?Flowmaster 80 Series Muffler
?83 Trans Am 15x7 Turbo Fin Wheels
?B.F.Goodrich Radial T/A 225/60-15
?Chevy 2.8L Heddman Headers (Going on soon)
Aol instant messenger: FIREAM
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Oct 5, 2001 | 03:37 PM
Correct me if Im wrong...
!st there should be a FAQ and/or a tech article. Second...
the smog pump/AIR system pump oxygen into the exhaust manifold to keep hydrocarbon of the exhaust ports
I thinks thats what it does...
am i right?
Old Oct 5, 2001 | 03:51 PM
un4givin89's Avatar
There is a tech article, but its very very lacking in detail. And confusing. I am researching this, becuase I think its something I may wish to do. It may be a month before I do it, cuase inspections are soon. But i will make notes, and take pictures and write a full article once I'm done and share my research.
Old Oct 5, 2001 | 05:52 PM
good that will benfit us all and I would appreciate it... Thanks....
Old Oct 5, 2001 | 08:07 PM
Engine: ZZ4 - 350
Sounds good man. I will look forward to a detailed tech article so I know what to do when I remove mine.
Later
Mike
Old Oct 5, 2001 | 09:01 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I removed most of my air system also. I just kept the pump, but ran a hose from the pump outlet straight to the CAT air tube. This still lets you lose the bulky manifold tubes. You can also remove the air management valve. Just plug the vacuum lines and tape up the connectors. It's not ECM controlled, so no "Check Engine" light, and you're legal. Don't have to worry about clogging your CAT over time either.
-1983 L69 Camaro Z28 305 H.O. (Bored .030 over,Teflon oil seals,Melling H.V. oil pump,Hyperetic pistons,chrome-moly rings,2040 Crane compu-cam) T-tops, 3:73 Open rear, BW T-5, Rebuilt E4ME 4 Barrel, Duel Snorkle Air Cleaner w/K&N Filter , Rhino Clutch, Crane 2040 Compu-cam, LS1 valve springs, porting, PST front end kit with new springs, and runs awesome!! Now for paint, interior, etc...etc.....Future Mods: Get rid of the 100 or so interior rattles.
[This message has been edited by Confuzed1 (edited October 05, 2001).]
Old Oct 6, 2001 | 04:05 PM
zee28's Avatar
Car: 86 iroc
hey unforgiven89,In virginia you will have a problem and never pass a underhood visual inspection unless you know someone.If your car is a sports car and older then 1994 the first thing they do is lift the hood.With this in mind Ill keep the pump and take the 1hp lost ,if that.I dont need to see my valve cover.
~white~86 IROC-Z
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
