Rear Oil Seal Installation ?
Old Oct 6, 2001 | 02:23 PM
86Chicken's Avatar
I have to take out my tranny and figured that while I was down there, I should replace the rear oil seal. It is 120K miles old and last time I was down there noticed it had a very small leak.
Removal looks easy; carefully pry out old one.
Installation is were I have a question. My service manual says I need a special tool for installation. Is this true? Can I just carefully tap it in with a punch/block of wood like I do for most other seals?
Dale
1986 FireBird
2.8L MPFI
1/2 CAI
Gutted Cat, No muffler
Was 700-R4 --> Now T5
Great cars aren't bought, they are built
Old Oct 6, 2001 | 09:48 PM
Mike89GTA's Avatar
Is 86 one or two piece? If two piece, the hardest part will be getting the old one out. I had to loosen all the main caps to get the top part out. The bottom part is easy though.... Putting the new ones in is easy too.
Old Oct 6, 2001 | 10:41 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Just grease the inner lip of the seal real good and leave the outer part dry.
Carefully roll the inner lip onto the crank surface making sure not to fold the lip over.
Install the rest of the way as a normal seal.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
Exxon Limited
Aug 9, 2015 08:13 PM
