Can a leaking intake cause excessive blowby?
Old Oct 7, 2001 | 05:29 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Im losing oil and notice oil spots on top of the waterpump and sometimes smoke would come out from underneath dripping to the header...
Compression and leak down tests were made and all cylinders were all close together.Oil comes out of the PCV hole pushing the PCV out when doing a quarter run...Not much oil leaks our when the car is sitting..
any ideas?
Daz
Old Oct 7, 2001 | 12:23 PM
crucial's Avatar
I have (had) the same problem with mine. Thought it was a bad intake and did everything I could to find it and cure it. Well after I tried a lot of things (new gaskets, checking intake for cracks,making sure EGR passages dont leak etc) then it came down to bad rings in cylinder #8. So that's why I'm building a new engine as we speak.
1991 Z28 6.0 TPI
360 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
