Dumb Q: How far out the diptstick tube should the dipstick stick?
Old Oct 7, 2001 | 10:59 AM
Biochem's Avatar
Car: 2002 SOM z28
Got that? When I replaced the headers a while ago, my friend mangled the oil dipstick... so I thought I'd just go to Autozone and pick up a new one. I got a (chrome) dipstick for something like 68-82 700R4. Well, I don't think it is long enough, because I can't read how much oil I have in there (after changing it last weekend even).
Acording to my friends, the dipstick should stick out the other end of the tube... makes sense. Well, this one didn't until I just cut off about 1" of the tube. How far does the stock one stick through? I'd really like to not cut off more tube than I needed to...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Oct 7, 2001 | 11:33 AM
firbird's Avatar
it is supposto stick out the tube but you might wanna do it the right way and get the correct one or it will never be really accurate. 68-82 700R4, shouldnt you have gotten a 84-92 one?
Old Oct 7, 2001 | 01:15 PM
Biochem's Avatar
Car: 2002 SOM z28
Well, it was the only style they had at the time... which was a long time ago (few months). Not to mention that I have all ready taken 1" off my stock tube to try and make this work with the new dipstick. Too late to go back...
Old Oct 7, 2001 | 02:30 PM
82camaro's Avatar
Car: 82 camaro SC
I would go to your nearest GM dealer and get a new tube and stick. They aren't that expensive, I had to replace mine when I swapped in the 700r4. The 700r4 I put was from an astro van--I didn't want to check it from the grill.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Oct 7, 2001 | 03:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well it shouldn't stick out at all if you put your stick into the tube all the way.
ICON Motorsports
Old Oct 7, 2001 | 05:01 PM
Damon's Avatar
The outer part of the dipstick shoves into the rubber grommet on the transmission housing about 1.25" but that measurement is meaningless. What really matters is the distance from the top edge of the trans grommet (there is a "lip" on the dipstick where it won't push in any further that lines up with the top of the grommet) to the tip of the dipstick. You should be able to still get an accurate measurement of this from your old disptick as long as you can still shove the dipstick through it.
BTW-
How much dip could a dipstick stick if a dsipstick could stick dip?
usdsk8er540
Sep 19, 2009 10:37 AM
camaronewbie
Mar 29, 2005 02:50 PM
gta ta
Feb 27, 2002 03:32 PM
Kat
Dec 16, 2000 11:26 AM
Biochem
Oct 18, 2000 05:49 PM
