Oil pressure question
Old Aug 8, 2005 | 12:42 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
The engine in my Formula has about 20,000 miles on it (According to the guy I bought the engine from). I have mechanical gauges, not electric, so I ASSUME the pressure readings are accurate. Anyhow, idling at like 800-900 rpm's I have about 30 pounds of oil pressure, and at higher rpm's it gets up to maybe about 60 or so.....
Is this acceptable for the mileage on the engine? I was under the impression that it would be a little higher....
I'm using 10w30 non-synthetic oil BTW. Would thicker oil bring the pressure up?
Thanks,
-Chris
Old Aug 8, 2005 | 01:12 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Well if that was my engine, i would be pretty happy with that pressure.
I would'nt ever put a thicker oil in though, it does'nt do a lot of good.
Old Aug 8, 2005 | 04:57 AM
ede's Avatar
ede
i'm suprised you didn't find this when you searched, 10 psi per 1000 rpm
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
