Quick response needed about distibutor gears...
Old Oct 6, 2001 | 05:40 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My block is an 86 LG4 with the stock cam.
I ordered a Crane Cams model 2050 cam.
I have an 87 TPI unit, 87 TPI heads, and 87 TPI distributor.
I was told that the distributor gears are different for roller motors.
Mine is a non-roller motor and I believe the 87 TPI is a roller one.
I ordered a new gear to put on the 87 TPI distributor, since I sold my old distributor.
Is the information I got correct?
Thanks.
Old Oct 6, 2001 | 07:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hydraulic roller cams are usually made out of the same material as flat tappet cams. So your stock dist gear will be fine.
{edit} I just re-read your post... if you have a 86 block, a factory type hydraulic roller will not work in it. You either have to use the style of roller cam that all the rest of us had been using for decades before the factories finally wised up, now referred to as a "retrofit" roller cam, or use a flat tappet one. The Crane 2050 is a regular flat tappet cam, so you don't have to worry about your dist gear with it either.
ICON Motorsports
[This message has been edited by RB83L69 (edited October 06, 2001).]
Old Oct 7, 2001 | 04:55 AM
Zepher's Avatar
So, you are saying that the gear on my 87 distibutor, which I haven't installed yet, will work with both my stock cam and the Crane Cam?
Is it just the material that the dist. gear is made of that is different, or is there a difference in the teeth or angles?
I don't want to damage the motor and at the same time I don't want to have to spend money on the new gear if I don't have to.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Oct 7, 2001 | 09:07 PM
Birmass's Avatar
Angles are the same on all small blocks. Just the material can be different.
88 firebird formula - Old time with TBI - 13.9 @103mph, 2.6 60ft
350 Vortec, Accel Pro-Ram MPFI
214int/224exh, .471int/.491exh
Edelbrock headers
T56 - SIX-speed
open 3.73's
3 inch Flowmaster catback
I love pissing those LS1's off
My Formula
Old Oct 8, 2001 | 02:17 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
That gear will work fine with the 2050. It's just some brands of rollers, namely solid rollers (Lunati) that need the bronze gear.
Old Oct 8, 2001 | 01:59 PM
Zepher's Avatar
Thanks,
I just wanted to double check.
Infested
May 22, 2018 11:56 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
