Bowtie Heads and 406
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
I have a 406 that has been pretty completely built out of the GM Performance Parts product line with exception of the cam, just the top of the line everything. This motor went 5.8x in the eigth in a 2600# car on a 200 shot.
My question lies in the heads. They are GM Bowtie Phase 2 iron heads. They have the blue aluminum rockers, HUGE double valve springs, and some of the fattest pushrods I've seen in a smallblock. They dont appear to have been ported anywhere.
I'm wondering if these heads are fully up to the task of handling all this power. And if there is alot more power to be found.
Thanks for any help guys.
-Justin
-Justin
Nothing is wrong with the heads....Just get them ported. There flow numbers stock are nothing great. But with a little work they will make good power. With not much metal removed i usually get 280 cfm around .500-550
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
There is huge power in those heads. Like the previous poster said you need to port them completely, but not excessively. You do not need new heads.
92projectcamaro
Jan 18, 2016 08:00 AM
C409
Sep 23, 2015 04:30 PM
