Blind Guy Needs Help With Starter Removal
Old Aug 12, 2005 | 01:45 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Hello all, I'm legally blind, I am very near sighted... I was wondering if someone had a diagram or could explain to me how the starter is bolted to the engine. I may have to replace it. My problem with my vision is that I have to get close to see things... If I have a diagram or an explanation, it would really help out.
I know it's on the passenger side, my friend helped when I replaced the battery cables...
91 Formula TPI 5 Speed..
Any tips on how it's best removed / replaced, etc... would be great.
Thanks,
Rafael
Old Aug 12, 2005 | 02:23 PM
stope21's Avatar
Get an f-body auto repair manul from autozone or pretty much any parts store, either chiltons or haynes will do. It should have instructions to where it is and how to remove. You can open it in the store and read it, but they are only like 15 bucks so its a great thing to have handy. I like to read mine at work even if I already know how to do something.
How do you drive if your sight is so bad? Thats cool that you still like automobiles so much
Old Aug 12, 2005 | 03:29 PM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
As stated above, a repair manual will tell you how to do it and is a great thing to have, but since you asked for an explanation, here it is.
(Important) Step 1 - Disconnect Negative batt cable
Then...
From under the car on the passenger side, above your oil pan and below your manifolds is a large cylinder with a smaller cylinder above it, that's your starter. The cylinder on top is the solenoid and has two or three studs sticking out of it with 3 wires held on with nuts. Remove these. At the end of the bottom part closest to your firewall is a square bolt flange with two bolts going up into your block. While holding the starter(It's heavy and you don't want it falling on you), unbolt them. Pull forward(out of flywheel teeth) and then down. Just a warning: it's going to be tight if you have the stock manifolds on there. You won't be able to see the nuts holding the wires on at all since they will be obstructed by the manifolds and the starter itself.
Just like in the shop manual:
Installation is the reverse of removal.
Good luck and enjoy.
-Matt
Old Aug 12, 2005 | 04:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
In addtion to what matt posted the two bolts that hold it to your engine are 9/16". The little bolt that holds the support bracket in place is rouhgly 8mm or so.
Old Aug 12, 2005 | 04:53 PM
stope21's Avatar
get er done! best of luck to ya luvofjah
Old Aug 12, 2005 | 07:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Out of curiosity, do you drive the car, or just maintain it?
Old Aug 14, 2005 | 04:04 PM
luvofjah's Avatar
Thanks for everyone's advice... I have both auto manuals, but hav msplaced them in my recent move... & don't recall any photos...
I do not see well enough to obtain a license... I'm building a Kitt replica... Ironic, huh? I know some people are like, "why tear up a nice car", but I have made nice improvemnets to it, new LCA & Panhard bar, Bilstein shocks and struts, STB, Wonder Bar, aluminum driveshaft, etc... In the closet waiting to go, jet hot coated Hooker 2055's, 3 inch magnaflow cat & super 40 muffler, MSD Digital ignition, wires, cap & rotor & coil, spohn sub frame connectors, etc.... Oh & Pro 5.0 shifter installed...
This car's never had it so nice
Rafael
Old Aug 14, 2005 | 04:11 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
yea looks like everyone covered all the details on the starter. onequestion i have is if you cant drive the car who does. that must suck not being able to drive a car that you put all this time and effort into it.
Old Aug 14, 2005 | 06:59 PM
Borsty's Avatar
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
spending all that money on a car you can never drive?
thats dedication. if i couldnt drive my car i wouldnt spend money on it. good for you man
Old Aug 14, 2005 | 08:12 PM
luvofjah's Avatar
I have driven it around my neighborhood a few times, after upgrading a part, but usually my licensed friends drive it. I grew up enjoying cars with my dad, we use to have a 67 or so, 3 speed vette once... I still enjoy cars, even though I do not drive....
Driving is somethign many people take for granted... it affects so many aspects of one's life...
The feeling I get when I'm in that car... I guess that's why I do it.
Rafael
Old Aug 14, 2005 | 08:16 PM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
Rafael
Laser eye surgery not an option?
Old Aug 14, 2005 | 09:22 PM
Borsty's Avatar
Car: 89 Trans am
would u like for me to take pictures of my starter and starter location? im probably putting it back in my car tommarow.
actually i have a pic (might not do to much good) of my starter and the braket the goes with it.
the bolts are upside down FYI (so i dont lose em lol)
Attached Thumbnails Blind Guy Needs Help With Starter Removal-dscn11066666.jpg
Old Aug 15, 2005 | 08:34 PM
Kwiksilverz28's Avatar
Laser eye surgery can only correct for what glasses could fix.
Good luck with you car, and your eyes! I work in a cataract and Lasik center as the QA/QI/Surgical Planner/Technician depending on the day. See lots of miracles.
Once again, good luck with the car!!!!!!
Old Aug 16, 2005 | 07:57 PM
luvofjah's Avatar
Alright, I found my books...
My starter turns fine & sometimes just clicks...
the solenoid on top has 2 big screws on the end... the top one goes to the batter cable... if I run a cable from the battery to the lower screw (under the one that the battery is normally hooked to) I will see if it cranks or clicks...
Next question... where would these shims be if I have some, by the head of the bolts or other end..??
As far as my sight goes, that is true about the laser surguery... I would rather wear a contact lens than have my eyes messed with...
Rafael
Old Aug 17, 2005 | 10:59 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
if it just clicks, the battery may be low enough to not allow it to turn over. just a thought.
Old Aug 17, 2005 | 11:03 AM
luvofjah's Avatar
It's not the battery.. I have a phat new yellow optima with a battery buddy hooked up to it... and the times it spins, it spins fast...
Old Aug 18, 2005 | 01:08 PM
Dirty Dave's Avatar
Car: 85 Berlinetta
Engine: sort of working
Transmission: B&M 700R4
Sounds like the starter may be bound up and in need of some shimming.
Old Aug 18, 2005 | 09:38 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Or a loose connection, make sure all connections are clean and snug.
Old Aug 19, 2005 | 02:36 AM
stope21's Avatar
or a good thumping w/ a rubber mallet/2x4
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Aug 14, 2015 08:25 PM
milk
Aug 10, 2015 06:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
