Oil pan gasket question
Old Aug 14, 2005 | 03:43 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I took the oil pan off my ZZ4 (new style block, ie 88+) so I could powder coat the pan. . I was going to order a new gasket from the dealer but they are about $60. The gasket looks like its rubber and not the typical cork or paper. Is it reuseable? It's still stuck to the block. Should I just use some rtv and put the pan back on? Thanks, Josh
Old Aug 14, 2005 | 05:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It might be reusable.
If you're going to replace it. Check the price of an aftermarket gasket kit at the parts store of your choice. If you were going to spend the whole $60 you'd be better off getting a Fel-Pro one-piece gasket.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
