Air Pump Delete Help
Old Aug 15, 2005 | 10:16 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I want to get rid of my air pump. I found the thread about removing the AC and air pump. My belt is a 3 groove belt, will the GM delete pully work for me? It looks to wide. What can I do?
My motor is a TBI that I was told originaly came from a pickup.
Old Aug 15, 2005 | 10:23 AM
TBI92Camaro's Avatar
Car: 92 Mustang Coupe/89 Camaro RS
Engine: 5.0 carb'd/305
Transmission: T5/T5
Axle/Gears: 3.73 and stock TrakLok/stock GM
you dont need the pulley. I rmeoved my pump and plugged off my exhaust manifold holes with pipe plugs/fittings. The pump came off and I got a shorter belt. Cant remember the size but I believe there is a write up on the main board about it in the tech area.
Old Aug 16, 2005 | 01:54 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Did you have any problems with the belt rubbing on the water pump? I Used an old belt to test and it looked real close.
Do you have any pics you could post?
Old Aug 16, 2005 | 03:15 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
Try these links out. I think they will give you an idea. The serpentine setups use a 6 rib instead of 3.
This tech article shows how to route the belt. You will want to go with the one on the left. Straight from the altenator to the powersteering pump, waterpump, crank, then to A/C
https://www.thirdgen.org/newdesign/t...rpentine.shtml
This has a part number for the delete pulley
https://www.thirdgen.org/techbb2/sho...hreadid=251909
Belt part #'s and length.
https://www.thirdgen.org/techbb2/sho...og+pump+delete
This should give you an idea. Hopefully you have the same serp setup as us since your LO3 came from a truck.
Old Aug 16, 2005 | 08:44 PM
Transmission: T5/T5
Nothing ever rubbed or anything, worked like a charm. I revved it into the higher RPm's plenty of times and it never popped off or anything.
Old Aug 17, 2005 | 02:33 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I saw those threads, but I am still not sure what to do since I don't have A/C
My LO3 is from an 88 pick up truck and has a skinny belt only 3 grooves in the belt.
Is there a 3 groove pully I can put on that bracket?
Was there ever a truck with a factory installed delete pully I could find in a junk yard?
Or is there a way to re-route what I have?
My setup looks just like the one in the pic but my bracketry is steel not aluminum and I have no A/C and a narrow belt.
Old Aug 17, 2005 | 07:30 AM
vrtc350's Avatar
Car: 81 Corvette
Do you have a pic of what you have?
The pulleys are fairly cheap to replace. You could get the 6 rib pulleys to use with the A/C delete pulley. I replaced my power steering pulley for $15.
I did find a thread(I can't find it now) where a guy relocated his altenator to the smog pump location. So it went from the altenator, over the idler pulley, down to the power steering I'm guessing. I couldn't see the rest of it. You may try searching for it. That could give you an idea anyhow.
Old Aug 18, 2005 | 02:52 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I looked up belts for an '88 truck at parts america and they show the belt as a six groove. Maybee I measured it wrong? do you count the lands and the grooves? How wide is the belt? could someone measure thiers. I will go measure the one on my car in the morning and post it.
Old Aug 18, 2005 | 01:13 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
The belt on my car is a half inch wide. (came frome a truck)
How wide is the belt on the factory installed LO3 in our cars?
Old Aug 18, 2005 | 03:07 PM
vrtc350's Avatar
Car: 81 Corvette
I'm not anywhere near to measure mine but I can tell you it's wider than 1/2 inch. That almost sound like a v-belt.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
mcquigg
Aug 13, 2015 02:26 PM
drathaar907
Aug 6, 2015 04:20 PM
