Coil's Bad...What To Replace It With
Old Aug 8, 2005 | 10:44 AM
klumb15's Avatar
its time to replace my ignition system, and i'm just wondering what kind of aftermarket coil should I go with? its a remote mounted style...does MSD or somebody make a good replacement? and if so, show me the link to it so i can get it ordered ASAP...thanks
Old Aug 11, 2005 | 11:20 AM
klumb15's Avatar
I know there is people out there running aftermarket coils...can anybody give me a recommendation on one..
Old Aug 11, 2005 | 12:24 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Yes MSD makes one that is a direct fit. I believe Accel does too. I expect there are many others too like chepos from Nehof and the like. Don't expect any gain in performance or milleage tho. Stock set up is good enough untill you start getting radical with your powerplant.
Old Aug 11, 2005 | 12:34 PM
klumb15's Avatar
yea i'm kinda built up, but it has been kinda acting up lately, so i figured i'd replace it with an aftermarket one while I have the excuss too..
http://thunderracing.com/catalog/?ac...vid=6&pcid=103
will any of those work fine?
Old Aug 11, 2005 | 12:37 PM
Engine: SBC, LS-x
The MSD has the best price and has been making this stuff longer than the other two. I'd grab that one.
Old Aug 11, 2005 | 12:38 PM
Engine: SBC, LS-x
And the folks at Thunder are good. Dealt with them a few times. Smooth as butter.
Old Aug 11, 2005 | 08:22 PM
klumb15's Avatar
okay i'll get that one..thanks
Old Aug 12, 2005 | 10:53 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
While I am typically a proponent for MSD in many instances, I've gone through four MSD coils over the past few years on my own cars. One in a vette, two on 3rd gen F-bods and one in the Cobra. While I typically shun Accel, the supercoil I bought over a decade ago is still going strong. I'm of two minds on both, but if I had to but one today, it likely wouldn't be an MSD unit... not too sure if it would be a supercoil again either. I'd probably try a different vendor next time. :shrug:
Old Aug 18, 2005 | 03:34 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I am a standard MSD fan. Love the coil I have on the Trans Am. Been good to me.
Old Aug 18, 2005 | 03:46 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I also like MSD as a rule, but I've had 2 of their coils fail on my in under 2 years each. One about 5 years ago on a truck-rod I had, and the other one yesterday in my 'Bird. Left me stranded for a while before I figured out the coil was the problem.....
92camaroJoe
Jul 29, 2023 07:57 PM
TheExaminer
Aug 25, 2015 07:34 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Newguy91rs
Aug 7, 2015 09:51 PM
