Long Or Short Water Pump?? HELP
Old Aug 16, 2005 | 06:40 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
before you bitch i looked at other threads but couldnt find what i was looking for.
i got a 1986 pontiac trans am, the motor is supposedly a 1972 350 4 bolt main. my question is i wanna spice up the look of the motor same and i purchased a short water pump its aluminum and polished. i want to know if this is the right one i need or do i need a long water pump. any help would be greeat
Old Aug 16, 2005 | 06:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You need the long water pump.
Old Aug 16, 2005 | 07:22 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
for sure, what years fit short water pump
cuz my motor might not be a 72, could be between 72 and 86, are they all long water pumps
also its a 350
Old Aug 16, 2005 | 07:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Every small block from 1969 and up used a long water pump except for the **DRUM ROLL** Corvette. Not sure on what specific years got what on the Corvette though.
Oh, that's not including the reverse rotation pumps or the reverse flow pumps. Those are their own animal all together.
Old Aug 16, 2005 | 08:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Reverse rotation pumps aren't their own animal, they're exactly the same, but with a different impeller.
Passenger car small blocks got the long pump in 1969, trucks got it later, in 72 or something like that.
Old Aug 16, 2005 | 08:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Short water pumps were used on factory models through the 60's. The heads didn't have accessory bolt holes and neither did the water pump. Unless you're building a complete custom application, you're going to want to install a long water pump. The long pump will have the proper bosses and holes on the body to mount accessories such as alternator and power steering pump. What year the engine is doesn't mean anything. It depends on what accessories you're planning on bolting onto it. Any late model car will need a long water pump.
Old Aug 16, 2005 | 09:34 PM
chesterfield's Avatar
Car: Pontiac
"Every small block from 1969 and up used a long water pump except for the **DRUM ROLL** Corvette."
and **DRUM ROLL** the V8 monza, V8sunbird, V8starfire.( Just for you trivia buffs.)
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
