Running a shorter belt question
Old Aug 17, 2005 | 01:59 PM
I-Roc with my Z's Avatar
Car: 1989 Iroc_Z
I have emissions...would running a shorter belt and bypassing the smog pump pulley work? Or would something go wrong? Then I would just put on previous belt when emissions came around. Less drag and little increase in HP...would it work or no?
Old Aug 17, 2005 | 09:20 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I think that will make it worse . Try findind out why you did not pass . Hear in NY they give you a print out of what you blow and the reson you failed . Then someone may be abel to help fix what's ale'in your Roc with the info . Good Luck
Old Aug 17, 2005 | 10:01 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You can't bypass the smaog pump without removing it. There will be interferance with the pulley hub (front of smog pump) if you do not remove it. When you do remove it you actually will use a longer belt.
1992 Trans Am
May 10, 2023 07:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
