everyone answer please
Old Oct 12, 2001 | 04:25 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
what are signs of too rich and the signs of to lean id like if you can tell me all u know NICK
Old Oct 12, 2001 | 04:27 PM
un4givin89's Avatar
I don't know.
un4givin89
Old Oct 12, 2001 | 04:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check your spark plugs, running rich they will be black, and lean I think perfectly clean or whitish. Also if you're running rich you will have a colorish exhaust gas, but I'm not sure of the color. Also I think black powder on the tailpipes means rich.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 13, 2001 | 12:29 PM
Vader's Avatar
91,
If your car still has the ECM, and it is fucntioning, you can use the Field Service Mode to monitor the fuel trim. The ECM that is constantly trying to enrich the mixture would indicate a lean condition, and vice-versa.
For those of us who don't have it memorized:
GM OBD I System Operation
This generation of engine control systems is a refinement of the first engine control computers and systems. First generation engine controls have some control over spark timing, a few output devices like the EFE system and EGR, and a minor role in fuel mixture adjustment. The OBD I system is designed to control and sense a wider range of functions than the earlier systems, including complete control of fuel delivery, and has proven to be much more reliable and effective.
The system has two basic modes of operation when the engine is running - Open Loop Mode and Closed Loop Mode. In a nutshell, Open Loop mode means the ECM is controlling the engine with essentially no feedback from the engine sensors - the control loop is said to be "open". Closed Loop mode means that the ECM sends control signals to the engine, scans the sensors for feedback to determine further corrections, then adjusts accordingly. The process is continuous, and the control loop is said to be "closed" since the sensors effectively communicate back to the ECM regarding the effectiveness of any adjustments made.
Open Loop Mode
When the starter is engaged, if the coolant temperature indicates less than 100°F and the intake air temperature is within 20°F of the coolant temperature, the cold start injector provides a spray of fuel or the cold enrichment subroutine allows longer fuel injector pulses on the service injectors. The cold start or cold enrichment subroutine is of eight seconds duration at a maximum. On a cold-start injector system the extra fuel is distributed to each cylinder via a air distribution system built into the bottom of the intake manifold. If the engine temperature is greater than 100°F, the cold start injector/subroutine is disabled by the cold start switch or ECM. Upon startup the ECM utilizes information in the PROM to establish the initial pulse rate for the injectors and the engine starts. At this time the engine is operating in Open Loop mode and will continue to do so until the engine warms up sufficiently to enable the oxygen sensor.
Closed Loop Mode
After a warm up period the ECM scans the sensors. If all sensors are operating and within their proper ranges, the ECM will enter Closed Loop operation. This means that the sensors are dynamically controlling the engine fuel and spark. The ECM receives information on intake air flow, coolant temperature, intake air temperature, exhaust gas oxygen content, barometric pressure, manifold pressure or vacuum, air conditioner status, power steering pump load, EGR operation, evaporative canister valve operation, engine RPM, vehicle speed, transmission gear selection, fuel pump status, combustion detonation, and throttle position. This information is used to calculate the proper ignition timing advance and pulse width for the injectors, and fires the injectors for the calculated period. This procedure is repeated continuously in very rapid sequence to maintain the optimum fuel air ratio. The electronic spark control components provide maximum advance, if engine knock is detected the spark is automatically retarded. This too, is a continuous process. It should be noted that the following components are matched for optimum performance - distributor EST module, ESC module, knock sensor and ECM PROM. These components are not interchangeable between 5.0L - 5.7L engines. In the event the information received is higher or lower than the normal range, a code will set in the ECM, and the Check Engine or Service Engine Soon lamp will light.
Block Learn / Integrator
The factory ECM/PCM has a learning capability which allows it to make corrections for minor variations in the fuel system to improve performance and driveability. There are two learning features. The Integrator and Block Learn (INT and BLM) and Block Learn Memory (BLM) cell. The INT and BLM feature is normal with a value of around 128 (the possible range is 0-255). If this value is higher than 128, it indicates that the ECM is adding fuel to the base fuel calculations because the system is running lean. A value lower than 128 indicates that the ECM is taking out fuel because the system is running rich. The integrator is a short term corrective action while the BLM is along term correction. The BLM value will change if the integrator has seen a condition which lasts for a longer period of time. There are from two to sixteen different cells which the ECM modifies, depending on RPM, airflow or manifold air pressure and other conditions such as AC on or off, etc. The ECM learns how much adjustment is required in each cell, retains it in memory, and applies these adjustments when the engine operates in that cell or RPM/Load Range. These features of the ECM allows the system to adjust itself constantly to your engine and assure peak performance for stock and other than stock engines.
NOTE: When the vehicle power is disconnected for repair or to clear diagnostic codes, the learning process has to begin all over again. To reinitialize the ECM, drive the vehicle at operating temperature with moderate acceleration and idle conditions for at least twenty minutes.
Performance PROMs typically change the parameters for fuel flow, fuel cut-off and spark advance-timing and will allow increased fuel flow and modify the spark advance curves during rapid acceleration. They can be programmed to tolerate differences in idle quality and manifold vacuum due to altered cam profiles and fuel systems.
Field Service Mode
On the OBDI ECMs, you can jump 'A' and 'B' terminals on the ALDL while the engine is running.
WARNING! This must be done after the engine is running. This is called "Field Service Mode" and will not harm the ECM.
If the ECM is in Open-Loop mode, the SES light will flash rapidly, about 2½ times per second. If it's in Closed-Loop mode, it will flash about once per second. When in Closed Loop mode, flashing less than once per second indicates the ECM is enriching the mixture above the 128 count base line. Flashing more than once per second indicates the ECM is leaning the mixture below the 128 base line.
Backup Fuel Mode
A 3.9K resistor installed between ALDL terminals 'A' and 'B' forces the ECM into Backup Fuel mode. This mode forces the ECM to use predetermined fuel calculations in the ECM PROM instead of the learned inputs in active RAM. This is more commonly referred to as the "Limp Home" mode of operation. Backup fuel is usually around 12:1 or richer from the factory.
Miscellaneous
An easy way to tell whether the PROM has been installed correctly in the PCM, and contains valid code set, is to watch the SERVICE ENGINE SOON light as you key on. Make sure the ignition is off for at least twenty seconds. Turn the key to the run position without starting the engine and watch the SES light. It should illuminate, then go out, then illuminate again and stay illuminated. This is called a SES light bounce. If you do not get a bounce then something is wrong and damage could result. If you try to start/run the engine when a proper SES light bounce is not present, then the computer will default to backup fuel and spark mode because it cannot execute a valid computer program. This can happen if the PROM is in backwards, or not seated, or contains a faulty program, or if the PCM has been damaged electrically.
Later,
Vader
Down with the Sickness
Adobe Acrobat Reader
Old Oct 14, 2001 | 12:44 AM
1BadAzzGT's Avatar
Some sign if you're running too rich would be a popping noise when decellerating(sp?) and also black smoke coming out of the pipes under hard accelleration (have a friend drive behind you).
Signs of running lean would be detonation (not enough fuel) and sort of sounds like a "ping" or "sizzle" noise.
One good way to really check is to crack on it real good and then immediately shut it down and check the plugs as someone suggested. White'ish means you're running very lean and are running out of fuel.
Hope that helps.
Founder, Tealnet.Com
'98 Mustang GT
My 98 GT
Mods: Vortech S trim, 42# inj, 5.4 Heads (ported/polished), custom ground cams, 99 intake, ATI 3 corer intercooler, Walbro 255 intank pump, Walbro 255 inline pump, Aeromotive adjustable fuel pressure regulator #13102, NO FMU!, Steeda Tri-Ax shifter, Steeda heavy duty LCA's, Steeda heavy duty UCA's, Steeda Chrome Moly subframes w/cross-brace, Steeda Cobra R hood (2 1/2" cowl), BBK 75mm TB, Pro M 80mm MAF, Eibach progressive springs, K&N Air, Cobra "R" rims, 31 spline Moser axles, SVO differential, Downs rear Girdle, FMS 3.73 gears, Cobra floor mats, Cobra leather shift ****, "A" pillar (Phantom White Gauges and custom gauge pod), Steeda race pedals, Mac offroad "H" pipe, hi-flo cats, and Borla XR1 catback.
Dyno #'s: 298.2rwhp/332.8rwtq (running rich 9:1 a/f)
Best ET to date: 13.42@104.91 (Temp F: 109 Humidity: 38 Barometer: 28.90) See the run on video!
Mods not installed: 3 core intercooler, ditching the FMU!
[This message has been edited by 1BadAzzGT (edited October 13, 2001).]
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
