Knock sensor
Old Aug 18, 2005 | 12:14 PM
stealthhit's Avatar
Car: 93 k1500/ soon 83 camaro
Knock sensor
I built a 350 for my pickup and changed it from a 305. I am the 305 TBi, Knock sensor and exhaust manifold. I have changed the Eprom to a stock 350 EProm. I am working on the Injectors for the TBI. I am going to get the stuff to do the Eprom chip. But I want to know what the difference is in a 305 knock sensor and a 350 knock sensor?
Old Aug 18, 2005 | 02:35 PM
Dirty Dave's Avatar
Car: 85 Berlinetta
Engine: sort of working
Transmission: B&M 700R4
I'd like to know the answer to this one as well, having seen references to a "350" knock sensor. I wouldn't think there'd be any difference as long as the output voltage is the same? Difference in sensitivity or connector end?
Old Aug 18, 2005 | 02:40 PM
stealthhit's Avatar
From what I have seen there is no difference other then part number. But they look identical and all so I am confused what the difference is between the 305 and 350 knock sensor is
Old Aug 18, 2005 | 03:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The knock frequency depends on the diameter of the bore, so 305 and 350 knock sensors are tuned to different frequencies.
Old Aug 18, 2005 | 03:26 PM
stealthhit's Avatar
Excellent that would explain some of the issues I am experiencing with the timing and the way my truck is running with that 350 now Thanks
Old Aug 24, 2005 | 12:42 PM
Dirty Dave's Avatar
Car: 85 Berlinetta
Well slap me silly That is a truly awesome & concise answer! That may explain some of the spurious readings I'm getting! Apeiron, udaman
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
