Which one is that exhaust port on heads?
Old Oct 14, 2001 | 01:21 AM
JMBoriss's Avatar
Which one of the sets of 2 is it? 1st or second? Thanks.
Old Oct 14, 2001 | 01:23 AM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
I am somewhat sure the exhaust port is the 2nd and the intake is the 1st
Old Oct 14, 2001 | 01:43 AM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
The one filled with black soot
Old Oct 14, 2001 | 08:22 AM
ede's Avatar
ede
might help if you were a little more descriptive in your question. are you asking whick valve it is? if so they run like this on a SBC
EI IE EI IE
front to rear or rear to front
or the 4 holes on the outside unmachined surface of the head
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
[This message has been edited by ede (edited October 14, 2001).]
Old Oct 14, 2001 | 09:26 AM
JMBoriss's Avatar
[QUOTE]Originally posted by ede:
[B]might help if you were a little more descriptive in your question. are you asking whick valve it is? if so they run like this on a SBC
EI IE EI IE
Sorry, I want to take off the heads and I need to pry them off with a crowbar or something in the exhaust port. So if I was sitting in the car facing forward. It would EI IE EI IE?
Old Oct 14, 2001 | 09:28 AM
JMBoriss's Avatar
I'm sorry. I wasn't thinking! OF COURSE they are going to be where the EXHAUST manifolds were! EXHAUST PORTS. DUH.
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
beastin91rs
Oct 9, 2015 07:38 AM
hayesaw0210
Aug 23, 2015 11:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
