CAM SHAFT ON ENGINE.
Old Oct 14, 2001 | 01:23 AM
JMBoriss's Avatar
Do you guys know what will happen if I put a .512 lift cam on a 85 z28 engine with stock heads? Thanks.
Old Oct 14, 2001 | 08:02 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
The valve springs that come on stock heads can't handle that kind of lift. You will experince coil bind and eventualy failure. Buy some valve springs that are reccomended to your cam and install them, also check your piston to valve clearance.
Old Oct 14, 2001 | 08:10 AM
ede's Avatar
ede
not a good match for your heads without changing springs and screw in studs. you'll need aftermarket retainers and trash the factory set up.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 14, 2001 | 09:49 AM
JMBoriss's Avatar
Explain to me what kind of studs and springs I need. And about how much that is going to cost me? Also, why would I need to check my P to V clearance? I'm just learning all about this kind of thing. I'm rebuilding my 305 and making it performance so I'll be posting on here a lot. THanks.
Old Oct 14, 2001 | 10:31 AM
Vader's Avatar
JM,
You'll almost certainly need longer push rods as well. You may need to machine the valve guides to allow for the extra lift, elongate the push rod guide holes to prevent push rod binding, and machine the spring seats to accomodate larger diameter valve springs. That would also be an excellent time to machine the rocker stud bosses and tap the holes for screwed studs.
As for the V/P clearance, you can calculate the valve lift and comapare it to the deck height at the moment of maximum valve lift. Once you get close to 0.050" or less, you should really use modelling clay between the valve and piston to check your calculations.
The "SEARCH" feature of the boards will undoubtedly be a very useful tool for you in your project. There is a lot of information in the archives.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theshackle
Aug 22, 2015 06:52 PM
jharrison5
Aug 19, 2015 05:53 PM
