Windshield Washer Sprays Not Working
Old Oct 14, 2001 | 04:30 AM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
So yea, they wont spray... Not that I really care.. But it'd be nice, just incase bird dookie, etc..
What all should I check?
(Most of the problems Ive had with the car I work for hours thinking its something drastic.. turns out it was just a missing part, etc.)
No License, No Hope.
FILTERCHARGED BABY
Old Oct 14, 2001 | 05:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Check the washer fluid hose where it attaches to the pump. For some reason a common problem seems to be the barb on the pump breaking off inside the line.
Old Oct 14, 2001 | 09:29 AM
Z28DJP1987's Avatar
One problem with the washers is the lack of use results in the punp drying out, and it needs to be primed. Try blowing some water through the hose to the pump, if this does not work, the pump needs replacing. Cost about $15.00 for the pump.
Old Oct 14, 2001 | 12:11 PM
Bawls's Avatar
Car: 1985 IROC-Z
Engine: LB9
Thanks. Ill give those suggestions a shot.
FILTERCHARGED BABY
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
TheExaminer
Aug 26, 2015 04:59 PM
92camaroJoe
Aug 13, 2015 06:07 AM
