What Head Gasket Should I use for 305 S/R torker Heads?
Old Aug 19, 2005 | 12:47 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I could use some sound experianced advise selecting a good head gasket for my motor.
I have a set of 42650 World products 305 S/R torker heads that I am putting on an early '80's 305.
World recomends the Fel Pro 7733pt-2 and the Fel Pro 1003
Wich should I use? Or is there another comparable gasket you would recomend? They recomend a 350 gasket due to the shape of the combustion chamber and valve size.
I only want to do this once so I want to use good gaskets that won't leak, blow out or give me problems down the road.
Let me know what you think.
Old Aug 19, 2005 | 10:34 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Anyone?
Old Aug 19, 2005 | 10:48 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The 7733 is the stock replacement gasket, the 1003 is the $$ better gasket. If your not worried about the cost, get the 1003's. I'm surprised they're recommending a large gasket for a 305.
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
