where is the power trunk release on a 86 trans am?
From: Newark,NJ The state where racing on I 78 rules.
Power trunk release????
86 Tramaro 90% Trans Am/ 10% IROC/Z (nose, hood,& fenders)
Trans Am Mods as of 1/10/01
3inch
T.E.S/Flowmaster setup,gutted cat,gutted maf,relocated mat,373 gears,upgraded factory chip,255 lph walpro f/pump & throttle body coolant bypass
njdaewoo@excite.com
New mods as of 6/10/01:
383sb engine
Comp Cam Xteme XR264hr-12
smog pump by-pass
3inch
njdaewoo@excite.com
383sb engine
smog pump by-pass
Tramaro,
You DO mean hatch release, right? The push button is on the right side of the dash, above the radio and heater controls and directly below the center AC outlets:
The release mechanism itself is located at the rear of the cargo well, and is part of the latch mechanism. The solenoid release and pull-down motor are hidden by the plastic trim at the cargo well.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Later,
Vader
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
colton_carlson
Mar 8, 2019 12:21 PM
