'90 3.1 V6 MFI
Old Oct 14, 2001 | 08:18 PM
Rd90RS's Avatar
'90 3.1 V6 MFI
I just changed engines in my 90 RS like for like (3.1) and now I have a problem making it idle properly. Throttle response is crisp, but idle speed doesn't seem to change from cold engine to warm. Also the idle seems so low that to put it in grear to move you must raise the rpms with the acc pedal. Also, what should the proper ignition timing be for this engine? I know that it is advanced plenty. any ideas?
Old Oct 15, 2001 | 12:04 AM
Vader's Avatar
RS,
Base timimng should be 6° BTC with a manual trans and 10° BTC with an auto trans, IIRC.
As for the idle conditions, check the IAC and its air passages for cleanliness. Set the TPS voltage and check the throttle minimum air position. There are directions for these procedures in the archives, and a quick search should find them for you.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
camario
Dec 20, 2011 10:17 PM
darrell_43748
Sep 22, 2011 01:02 AM
doctormdm
Jan 14, 2010 07:35 PM
ohiotemplar
Sep 11, 2007 03:48 AM
c-5invalid
Nov 9, 2001 05:57 PM
31, 90, v6
