noisy air conditioning compressor
Old Oct 14, 2001 | 09:37 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
i noticed that my individual belts on my car make alot of noise squeeling and whatnot, but as i was observing my car idle, the freakin ac compressor was making alot of noise. its really annoying, and right above the compressor i noticed alot of what looks like oil on the foam padding on the underside of the hood. it appeared to be coming from the compressor. what is the deal? do i need to replace anything? thanks
1987 LG4 Camaro z28
Performance
KN airfilter, flowmaster 80 series and catco high flow converter, 180* thermostat, edelbrock performer intake
System
Panasonic CQ-DF200U deck, fosgate speakers (hpc1369, frc2246), fosgate 400a4 amp
Old Oct 15, 2001 | 01:00 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like the compressor is dying, in a working system , there is oil, the oil could be flinging up from the front seal in the compressor.
The noise will come when the system loses the oil and the compressor starts to lock up.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Oct 15, 2001 | 12:28 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yep, sounds to me like your compressor's going.Had it happen to both my 92 RS and 91 S10 Blazer this year.Soon after all the oil blows out of it, it will seize and the serpentine belt will start to smoke,unless you turn off the air, or disconnect the ac clutch connector.Time for a new compressor is coming quickly.
When you replace it, be sure to put new seals in the hose connector on the back and replace the dryer/accumulator as well.
I would stay with R12 also,even though it's more expensive than the new stuff (R134) it actually works better,and the F-body system doesn't hold that much anyway.
-Rich-
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Apr 14, 2016 08:52 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
