Car idles rough in drive, but not nuetral or Park, why?
Old Aug 21, 2005 | 12:20 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
The Tranny shifts fine and the mount was replaced a couple months ago so that can't be it. Any ideas?
Old Aug 21, 2005 | 09:20 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
A couple of questions to help me figure out where you're at.
1. Is the S.E.S. light coming on to indicate a stored trouble code?
2. Have you checked the motor mounts?
3. When was the last time your car got a tune-up?
4. Have you checked for vacuum leaks?
Old Aug 21, 2005 | 01:33 PM
Car: 1994 Trans Am
Also, when I shift into any drive gear or Reverse there is a chunking feeling. Idle is more like a grinding sound with some vibrations, not horrible, but definately noticeable vibrations.
1) no ses lights
2) haven't yet
3) before I bought it in January
4) checked, found none.
Old Aug 21, 2005 | 02:18 PM
Car: 1989 Camaro
Check the motor mounts and universal joints on the driveshaft and let me know what you find out.
Old Aug 21, 2005 | 02:51 PM
sellmanb's Avatar
Car: '86 Berlinetta
and trans mount... you'll probably have to take the mounting plate off to really inspect the transmission mount.
Old Aug 21, 2005 | 03:24 PM
Car: 1994 Trans Am
Re: Car idles rough in drive, but not nuetral or Park, why?
Iroczracer07, I will check those things. And I might change the tranny fluid.
Thanks.
Old Aug 21, 2005 | 05:49 PM
Car: 1989 Camaro
Wade787b
Sep 29, 2015 01:15 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
