tap,tap,tap,tap
Old Oct 14, 2001 | 11:34 AM
e-man's Avatar
Car: 89 formula
Engine: 383
tap,tap,tap,tap
The taping sound is coming from the passenger side and it sounds like its coming from the head.When I bring the revs up its not as loud.I checked the rocker arms their not loose, no exhaust leaks.I dont have a clue what it could be?
89 350 TPI,comp cam,edelbrock intake base,SLP headers,highflo cats,flomaster cat back,accel 300+ ign,ported plenum and runners,ported maf,auto w/shiftkit,cold air induction,AFPR,custom chip,3.23 posie best ET 14.011@98.72mph without cam/New best 13.926@98.27mph
Old Oct 14, 2001 | 11:40 AM
Vader's Avatar
E,
Collapsed lifter? Bent push rod? Broken valve spring? Rocker/cover interference? Cracked spark plug? Wrist pin? Accessory belt dry/cracked? A.I.R. check valve? Bent valve? Y-pipe? Flexplate?
Just some guesses...
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 15, 2001 | 02:17 PM
85transamtpi's Avatar
never mind
[This message has been edited by 85transamtpi (edited October 15, 2001).]
Fred SS
Oct 12, 2015 11:27 AM
steimel94
Sep 20, 2015 12:46 PM
gta892000
Sep 16, 2015 12:37 AM
Ragtop Man
Sep 12, 2015 12:23 AM
dimented24x7
Sep 6, 2015 03:51 PM
