Loosing Power at High End
Old Oct 17, 2001 | 08:11 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
What would cause this? My injectors aren't looking to good when they spray...spurtin every once in awhile. Would this hurt my power up top? Cause my car feels REAL strong down low until 3rd gear...wondering what different kinds of things cause power loss at the high end. Thanks a lot guys.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Oct 17, 2001 | 08:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Weak valve springs, plugged fuel filter or weak fuel pump (not enough fuel flow to the engine - "Flow", not pressure). Pressure is only part of it. You also need the volume especially at the top end.
And like you mentioned. Dirty fuel injectors.
The chance if it being an ignition problem is slim. Lack of power on the top end is usually fuel.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Oct 17, 2001 | 08:26 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Definitly could be the injectors,sounds like your lacking fuel. If that isn't it, could be the fuel pump. But if your injectors are as bad as you say they are,most likely that's it.
Old Oct 17, 2001 | 08:34 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Well, it looks like I just have something else to replace with aftermarket parts. "Yes I will take a pair of Turbocity flow matched injectors please, thank you."
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
novaderrik
Aug 10, 2015 12:44 PM
