oil pressure sender
Old Aug 24, 2005 | 09:02 PM
rocz's Avatar
Car: 88 IROC-Z 91 RS
Engine: 358 in the roc 305 in the rs
Transmission: 700's
oil pressure sender
how will it affect the car (88 iroc tpi 358) if the sender down on the driver side is not plugged in.
Old Aug 24, 2005 | 10:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You will have no fuel pump relay backup and your oil pressure gauge will not work.
Old Nov 13, 2005 | 04:37 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: oil pressure sender
It's not a sender it's a switch, your oil gauge will still work because the oil sending unit is up top next to the distributor.
The oil sender/switch combo didn't come out until 91', or so.
I relocated mine, but as you can see, there are two sensors.
Old Nov 15, 2005 | 01:34 PM
89 tbi bird's Avatar
Car: 89 FireChicken
Engine: TBI
89 with sender and switch together
Old Nov 15, 2005 | 11:16 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
89' Camaros do not.
Old Nov 15, 2005 | 11:20 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
mine and my friends 89 camaros DO
Old Nov 15, 2005 | 11:52 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Previous owner of my brother's 89' IROCZ must have changed it, guess he didn't like replacing 2 sensors when only one-half of it is failing. As long as the fuel pump relay is working, neither one is critical.
Old Nov 15, 2005 | 11:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
makes sense, cuz the rear of the block is just plugged from factory. and thats an easy port for a sender/sensor.
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
