will this cause flucuating fuel pressure readings??
Old Oct 16, 2001 | 05:16 PM
breathment's Avatar
ok, batch fire means that more then one injector is firing at once right? which to my simple mind makes no since, because wouldn't that cause bad MPG?? well either way, would batch fire cause the fuel pressure to fluctuate, or should if be smooth and constant? my readings kind look like that of vaccum readings on a engine with a bad valve, just barley fluctuating, but quickly.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 17, 2001 | 10:47 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Mine never fluctuated. I suppose either you have a bad fp gauge or something is wrong with your pump or regulator. And yes, I always thought batch fire was kinda sloppy too.
specialized
Jun 18, 2022 09:26 AM
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
