setting/adjusting balancer and adj. pointer...TDC???
Old Aug 25, 2005 | 06:50 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Ok, Ive searched for this and got a few vauge answers. I got a GMPP 8" balancer for my 383, comp cam and timing chain, and a summit adjustable timing pointer. My question to you gentlemen is this: According to the cam and crank gears, when should I set the balancer/pointer for TDC for the #1 piston? Should they be at 12 and 12, or dot to dot (cam at 6, crank at 12)? It seems that it should be 12 and 12 because dot to dot seems to be the top of the exhaust stroke, right before the intake stroke.
Some guy at my work said the only cams you install with the marks at 12 and 12 is old 427 (421?) Pontiac motors. But I just see this lining up dot to dot on the compression stroke. HELP!
Old Aug 25, 2005 | 06:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The engine is at #1 TDC whenever the crank dot is at the top, regardless of where the cam dot is.
Old Aug 25, 2005 | 07:30 PM
spills's Avatar
Car: 89 RS
that makes sense. How about when #1 is TDC on the compression stroke? Just outta curiosity
Old Aug 25, 2005 | 07:45 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
When the timing marks on the gears are aligned 6 and 12
the engine is at TDC fireing #6. you have to rotate the motor's crankshaft 1 complete turn from there so the timing marks are at 12 and 12. This position is TDC #1 fireing.
This not a good way to align and set the adjustable timing tab for the balancer. You should use a piston stop to find true TDC. Easiest with the heads off. But can be done with the heads on. Make sure the valves/ rockers on that cylinder (#1) are loosened off completely so the piston stop does not hit a valve during checking TDC. True TDC is exactly 1/2 way between the points where the piston stop stops crank rotation forward and backward.
Old Aug 29, 2005 | 02:59 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
But what do you do when you buy a piston stop, thread it in all the way, and the piston never touches it? I bought one from Summit and can crank the motor over by hand all day and never touch the piston stop.....
Old Aug 29, 2005 | 03:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The angle of the plugs in your heads could be too parallel to the deck, or you could have dished pistons. Unfortunately then you might just have to pull the head.
Old Aug 29, 2005 | 03:07 PM
vernw's Avatar
Sure hope not. Is there a chance that the piston stop is too short?
Old Aug 29, 2005 | 03:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Maybe, which one did you get? I have the Crane one I think.
Old Aug 29, 2005 | 03:31 PM
vernw's Avatar
I got the "Tavia Piston Stop Tools Piston Stop, Top Dead Center Stop, Cylinder Heads On, Spark Plug Style, 14mm, Adjustable Depth, Kit" for $15.xx plus overnight shipping, received it on Friday so I could TRY to get it resolved over the weekend.
Old Sep 12, 2005 | 01:38 PM
vernw's Avatar
OK, did the check over the weekend. Mid-point between the 2 marks (rotating one way until it hits the stop and make a mark, go other direction ans mark the point where it stops) ends up being 4*BTDC. Sounds to me like I'mrunning 4* less timing that I thought I was.....
Old Sep 12, 2005 | 06:59 PM
F-BIRD'88's Avatar
I make my own piston stop that works with smog heads ( horizontal parrallel plug placement.)
I knock the porceline out of a old spark plug. I get a 3/8" steel tube and weld it in the hole cockeyed so it points down toward the piston when screwed in. It works. Ya have to lossen off the valves for that cylinder so thye don;t contact the piston stop during checking.
For a dished piston the end of the rod has to be a little longer. may need to bend the end too.
Attached Thumbnails setting/adjusting balancer and adj. pointer...TDC???-pistonstop1.jpg
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
