knock sensor
Old Oct 17, 2001 | 09:53 PM
cobrakiller1989's Avatar
knock sensor
I have heard that you should change htis to a 350 knock sensor when changing from a 305 to a 350...any truth to that? also, where is it?
thanks alot
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
Old Oct 17, 2001 | 10:28 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yeah, it's a good idea. The knock sensor is in the block on the passenger side, near the starter.
Old Oct 18, 2001 | 09:58 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
You should change the knock sensor and module .The module is located between the master cylinder and LF fender, on the firewall. I think it has a 5 pin connector on it.
-Rich-
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
