160 degree thermo.... question
Old Oct 17, 2001 | 08:45 PM
Camaro8316's Avatar
Hey everyone, I just bought my Camaro about a month ago, and I got a 160 degree Thermostat yesterday- the guy at A&A told me I need a chip to use the new thermostat. Is this true or could i just put it in with the car stock? Thanks
Old Oct 17, 2001 | 08:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you're car is computer controlled I do believe you need some sort of chip for the system operate properly, you're car will still run. And depending where you're from I wouldn't recommend putting it in with winter coming, unless you leave where it doesn't get that cold. I just recently changed the 160* out for a 180* since I go to college in the mountains and it is already freezing here with 25mph winds constantly.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 18, 2001 | 01:17 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
</font>
Did you have to change your fan switch as well when you changed to a 180* T-stat?
Old Oct 18, 2001 | 06:24 PM
Abubaca's Avatar
Don't do it without a chip. I did it that way, and had problems. First, I dumped tons of gas. My mileage sucked. Second, My emmissions were, through the roof. Third, (if I had a cat) my understanding would be that it would've been clogged by all the extra fuel NOT being burned. I had no heat in the winter either...some I guess, but not much!!! I never really even saw a performance gain. Needless to say, I switched back to a 180. No problems since.
krisner89
Oct 10, 2015 06:03 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
