Side fender light on a 89 formula?
Old Oct 18, 2001 | 05:11 PM
89Firebird Formula350's Avatar
Can anybody tell me what kind of bulb this is? I need to replace it, any model # or any help would be great, thanks!
Old Oct 18, 2001 | 10:24 PM
Enkil's Avatar
Go to jiffylube and ask for an L194.. Should be the bulb you need. you can have them put it in if you want, it's only around 5 bucks or so.. You wouldn't really be saving all THAT much if you did it yourself.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Oct 18, 2001 | 10:28 PM
Enkil's Avatar
Oh, and, umm... Reach up under the fender. It might take some pretzling of your arm, but there's a rubber plug in the lense of the light. It twists about an eight of a turn, then pulls straight out. The bulb also just pulls straight out, although sometimes heat will cause the plastic to melt around the bulb and make it a little hard to get out.
In my Camaro, the passenger side fender light thing was actually easier to get to from the top, although I had to remove my battery. (But I was in the process of changing that anyways, so.. worked out pretty well for me. heh)
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Randomtask2
Aug 13, 2015 01:57 AM
Omega
Aug 10, 2015 12:46 PM
