roller rockers
Old Aug 28, 2005 | 09:52 AM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
roller rockers
Can I use non aligning roller rockers in a L98 350 TPI engine? Or do I have to use them with guideplates?
Old Aug 28, 2005 | 09:26 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
NSA rockers need guideplates, period.
Old Aug 29, 2005 | 05:17 AM
ede's Avatar
ede
it would depend on what head you have, since you never said. if it's stock haed with self aligning rockers you'd need the non self aligning rockers and a method to align then, like guide plates. big point to remember is to no mix locating methods.
Old Aug 30, 2005 | 07:26 AM
Car: '87 Iroc-Z
yeah, they're stock head. SO just buy guideplates. Thanks Alot Guyz
Old Aug 30, 2005 | 11:20 AM
ede's Avatar
ede
no the stock head is set up for SA rockers so you'd need to change that, simplying installing a non sa rocker wouldn't do the job
Old Aug 30, 2005 | 04:53 PM
Car: '87 Iroc-Z
Look, you just said using stock heads I would have to use guideplates also with nonSA rockers.!?
Which is it?
Old Aug 30, 2005 | 05:44 PM
Guideplates need to be installed using screw in studs which stock iron heads do not have. You will need self-aligning roller rockers for you setup. Also make sure that the pushrod slots in the head do not interfere with the rockers ability to 'self-align'.
Old Aug 30, 2005 | 06:34 PM
Car: '87 Iroc-Z
So I need to buy some new rockers. Anyone wanna buy some Proform 1.5 Roller Rockers?
Old Aug 31, 2005 | 05:06 AM
ede's Avatar
ede
sorry typed faster than i was thinking
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
