How much HP can stock rods and crank take?
Old Oct 19, 2001 | 01:11 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Here's the setup on my engine's bottom end:
forged pistons
ARP rod bolts
ARP studs in the mains
stock crank .010 under
stock rods
completely balanced assembly
How much HP can this setup take? I'm sure my engine combo isn't gonna make over 400, I'm estimating more like 350. But if I decide to squeeze it will I blow the bottom end out? Or will I be OK just so long as I don't spin it too fast?
Whoops, forgot to add, it's a 2-bolt.
[This message has been edited by ViciousZ (edited October 19, 2001).]
Old Oct 19, 2001 | 01:16 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the main cause for rod/bearing failure is loss of oil flow. The bearing overheats and melts. The oil flow can be lost because the nut backs off, the rod side clearance too high or bc the bearing lost the oil wedge due to clearance. Maintain the oil flow and all else will fix itself.
I have seen stock rods live at 6500+ untouched except for bolts.
89rs 400sb 4.10 gear and a few aluminum things
[This message has been edited by jcb999 (edited October 19, 2001).]
Old Oct 19, 2001 | 02:00 PM
Damon's Avatar
Assuming perfect clearances on everything (and that's the REAL key to making the bottom end live- FAR more so than having trick aftermarket forge parts) I'll say you're good for 6500 RPM (occasional blasts to 6800) and roughly 500HP.
Remember it's RPMs that kill bottom ends, not torque.
Old Oct 19, 2001 | 03:00 PM
ede's Avatar
ede
run good bolts, ARPs, polish and blueprint the crank, chamfer the oil holes, run a good pump, M55 w/#26 mr gasket spring and you should be good for 400 and more HP.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 04:36 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I agree whole heartidly with Damon. RPM kills a motor, not power. Make sure you use good fasteners, and get the clearances correct and your good to go. I would even go as far as 7500 if the bottom end was balanced. My Camaro has seen 6700 and the bottom end is all stock except for pistons.
Joshua Johnston
1991 Z-28
350, T-5, K&N, Ported Vortec heads, Edelbrock RPM, Holley 750 D.P., HEI, 11.07:1 CR, Comp Cams Roller-.510"/.520"-282*/288* dur., Shorty Headers, Dual 2.5 Exhaust, Dynomax Bullet Mufflers, T&R Motorsports custom air intake, Bald tires
Reborn756
Sep 4, 2015 03:42 AM
BBSDesigns
Aug 11, 2015 07:39 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
