MY CAR IS VIBRATING...HELP PLEASE!!!!!
Old Oct 18, 2001 | 03:44 PM
deadtrend1's Avatar
I was driving home from school, and i stopped at work to pick up my check. When i came out of work, when i started it it was vibrating like hell. Its a manual transmission and i know the clutch needs adjusted, but i got it home and reset the computer and all, still does it. Also i noticed that its blowing a little black smoke out of the pipes. I dont think its missing because all the plugs are new and shes idling fine, just vibrates but its at normal rpms. ANY CLUES????
http://members.aol.com/deadtrend1/index.html
Old Oct 18, 2001 | 06:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not to be a jerk, but....
Rule #1 of problems that occur right after you work on something: you screwed something up in the process. Go back and retrace your steps. I'd bet any amount of money that have a plug wire that has come off, or is touching the exhaust and has burnt through (driver's side, #3 & #5 are the first I'd check), or something like that.
Black smoke out the pipes = unburend fuel = a miss. Shaking = a miss. Check your ignition system thoroughly.
Rule #0 of life in general:
"The simplest explanation that fits all the facts is usually the right one".
—Occam (ancient Greek know-it-all)
ICON Motorsports
Old Oct 18, 2001 | 10:05 PM
deadtrend1's Avatar
The thing was that i didn't work on it, it was fine for a long time then out of nowhere.
I found the problem anyways, spark plug wire 6 melted on my exhaust manafold and was sparking. I had to wait till nightfall to find that one. Thanx though.
~Tim
Old Oct 18, 2001 | 10:13 PM
iroc5speed's Avatar
hey man, I don't know if you know this but your clutch is hydraulic, so it self-adjusts(unless it was made before '85). just FYI. if it needs adjustment then that probably means it's just going bad
Old Oct 18, 2001 | 11:01 PM
deadtrend1's Avatar
oh really .. damn...its just that it makes a whining sound like its still spinning when im sittin in neutral, then i press it goes away. Let go, same sound etc...
Old Oct 19, 2001 | 05:06 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
if the tranny whines when it is in neutral with the clutch out the bearings on the mainshaft of your tranny are prolly bad. they make noise when they get loose and wore out.
86 IROC
43,000 miles
305/700R4/3.23 gears
maroon, gold stickers, black interior, T-Tops.
current mods.
shift kit
headers
cat back exhaust
mods planned for this winter
cam
3.73 gears
subframe connecters
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
