Hydraulic floor jack Repair
Old Oct 19, 2001 | 05:07 AM
ronterry's Avatar
Car: '94 Corvette
I've got one of these Larin 3 ton floor jacks, and lately it well slowly lower over an hour or so under load.
Does anybody know what needs to be done to service these jacks. Does all need is hydraulic fluid, the jack does have a zerk fitting, or does this sound like a seal ?
(Lost instruction a while ago)
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Oct 19, 2001 | 07:04 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like one of the seals on the pressure side is bleeding off.
If you have the handle turned so that it wont lower and it still does, it might be time for a new one or a rebiuld of the old one.
FWIW...most jacks will bleed a little over that much time...thats what jackstands are for.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Oct 19, 2001 | 07:26 AM
ede's Avatar
ede
some older jacks use a flat leater washer type seal, if it has that flip the seal over and use the other side of it. if it's o rings or a vee type seal replace them. first make sure the fluid level is correct. i wouldn't be trusting a jack to hold anything up, use jack stands.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 10:56 AM
82camaro's Avatar
Car: 82 camaro SC
I agree on the jackstand idea. The jack is just used to lift the car, not maintain it safely.
bin laden song:
http://www.gotlaughs.com/funpages/bin2.cfm
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Oct 19, 2001 | 01:02 PM
82z's Avatar
82z
How do you know it lowers over an hour? Don't the jackstands hold the car up? The zerk is just to lube the pivot point.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Oct 19, 2001 | 06:14 PM
ronterry's Avatar
Car: '94 Corvette
I guess I'm busted !!!
Well, sometimes I just throw it under there to do little things, nothing where my whole body is under there, but things like an oil filter - BLAM.
Just one day It started making a ticking noise under load, and would go flat after about an hour. This realy opened my eyes not to trust these jacks, not even for a second !!! I mean these could let go at any time, 3 tons or 50 tons it doesn't matter. Oh well, I think I'll use it to jack things up. I'm going to have to run out, and get some smaller jack stands.
Oh yea, I had a experience with my Camaro rolling off ramps about 8 years ago, almost runing me over. So you guys should also spread to word to use wheel chocks. I hear alot fokes putting to much faith in the parking praw.
Thanks----
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Oct 19, 2001 | 10:15 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ronterry:
Thanks----
Ron
</font>
RT,
Better to get "busted" by a few of us than 3,400 pounds of 'F' Car in your face.
Get some good jack stands (four of them) and then you can be fairly safe. Save the jack for raising and lowering only, and the occasional transmission, shocks, springs, and differential service.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
LC2 TECH
Oct 13, 2015 11:53 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
